#21 | |
#22 | |
#23 |
Trinity
Have you got a steep hill? - you could try bump starting it.
Failing that, have you got a cliff? - you could push it over, well it is Curvy afterall ![]() |
#24 |
Is the vacuum opening the fuel tap under the tank? Has the kill switch/ignition etc been exposed to damp/wet? It sounds like a fuel problem though.
#25 |
Major problem I had with mine, twice, was that there was water in the fuel. I drained the tank into a bucket (water is heavier than petrol). Then drain both of the carbs. Put in fresh fuel & it may start. It is just a thought & could be worth checking out.
Flickr: http://www.flickr.com/photos/croozenooze/ Facebook : https://www.facebook.com/colin.hughes.1213?ref=tn_tnmn Yoo Toob https://www.youtube.com/channel/UCjG...eMWUx4Ud2dK-yA |
#26 |
I'd go with Mr C's advice. The other things required to get a bike to start seem to be fine (battery, spark plugs etc.)
#27 |
Trinity
Sounds like a big waste of fuel - you only need to drain the carbs.
#28 |
Where in Manchester? If you are on the Warrington side I may be able to have a quick look with you, I don't know huge amounts but I have a curvy?
#29 |
Also, check the choke is opening and closing as it should do.
Good luck, hope you get it sorted! |
#30 |
Will a Curvy still crank over on the starter if the kill switch is faulty or in the off position?
Cant get my new Sv650 K5 to start, have i flooded it? | Mej | SV Talk, Tuning & Tweaking | 30 | 09-12-08 08:55 PM |
FIGURED OUT WHY 2006 SV650 WON'T START | LAURENT VALLAT | SV Talk, Tuning & Tweaking | 17 | 04-10-06 02:28 PM |
2006 SV650 WON'T START | LAURENT VALLAT | SV Talk, Tuning & Tweaking | 6 | 02-10-06 08:31 PM |
SV650 won't start - possible battery problem? | B | SV Talk, Tuning & Tweaking | 6 | 08-08-06 07:20 AM |
SV650 won't start | spmorgan | SV Talk, Tuning & Tweaking | 1 | 21-11-04 07:49 PM |
