Old 27-09-09, 01:06 PM   #1
Stuuk1
Default Trouble finding neutral.
Ok, Ive done a search and find plent about the sv gearboxes but cant seem to find anything like my problem.
My problem is with finding neutral while the engine is running, I simply cant!
It will flick between 1st and 2nd sometimes being a little stiff, but as soon as i turn the engine off with ignition on, the easiest thing in the world to find is neutral! Why is this?!
Slightly annoying as I have electric gates in to an underground carpark which i need to put bike in neutral to get buzzer out of my pocket and turning the engine off each time is kinda annoying..!
Old 27-09-09, 01:07 PM   #2
Stuuk1
Default Re: Gearbox Neutral...
Forgot to mention: My bike is a 52 reg SV 650
Old 27-09-09, 01:10 PM   #3
Alpinestarhero
Have you adjusted the chain, cleaned and lubed the chain, and adjusted the clutch at the worm drive?
Old 27-09-09, 01:12 PM   #4
Stuuk1
I have only cleaned and lubed the chain.. Perhaps Ill ask my mechanic friend to do the other stuff you mentioned. Cheers buddy
Old 27-09-09, 01:21 PM   #5
Alpinestarhero
Yea, try adjusting the chain tension. Make sure your mechanic adjusts the worm drive and not just the cable tension (the worm drive is hidden behind the front sprocket cover). Actualy, that one you might be able to do yourself, I do mine...and I'm a bit scaredey of doing things on my bike (I let my dad adjust the chain tension, although I understand how to do it)
Anyway, dead easy to do - take off the front sprocket cover (3 x 8mm bolts, need a long socket), then slack the clutch cable right off at both ends. Place a flat-headed screw driver in the slot for the worm-drive, hold it, and undo the 10mm nut (might need a bit of a tug, dont skin your knuckles!). Turn the worm drive in with the screw driver until it just touches something, then back off 1/8 of a turn. Hold it there, and tighten the 10 mm nut back up. Re-tighten the clutch cable (remember to leave a little slack for when you turn the handlebars side-to-side). Oh, get some oil on the worm drive mechanism and some on the gear selector shaft to it all runs smoothly
Matt
Old 28-09-09, 04:26 PM   #6
TheOnlyNemesis
Default Re: Trouble finding neutral.
sounds like a problem i was having and it was the clutch and like alpine says, you can do it yourself quite easy, just take the cover off and adjust the bolts to make it a bit tighter, but mien was where the clutch cable had stretched and the clutch wasn't engaging when pulling in except for when i was moving.
Old 28-09-09, 05:01 PM   #7
Thingus
whenever i can't find neutral i roll forward half a foot and try again ^.^ best of luckies
Old 28-09-09, 06:46 PM   #8
Alpinestarhero
Ah, the good ol' neutral shuffle.
I once almost wrote a song about such a dance
Old 28-09-09, 09:00 PM   #9
Thingus
That's a floor filler i'm sure =D
Old 28-09-09, 09:36 PM   #10
s7uyj
may sound obvious but you havent got too much oil have you? thats a classic and makes finding neutral a bugger!
hi need help finding gaskets thelilbigtony Bikes - Talk & Issues 2 17-01-09 01:36 PM
finding a job after uni riktherider Idle Banter 6 07-07-08 08:32 PM
Finding a Kitten? Demonz Idle Banter 23 24-07-06 09:01 PM
trouble getting neutral? kwak zzr Bikes - Talk & Issues 7 16-03-06 09:29 PM
Finding Neutral DanDare SV Talk, Tuning & Tweaking 11 17-05-05 11:38 AM
