Old 23-04-12, 02:07 PM   #111
Default Re: Potential pointy Adjuster Plates Group Buy
Old 23-04-12, 02:19 PM   #112
Nobbylad
Nobbylad's Avatar
bish bash bosh. the magic number
nobbylad owes me a pint for being wrong... lol
thanks to all so far...
Lance
I think that you owe me a pint to thank me for the reverse psychology I implemented in order to make people think you would only produce 25 and therefore encourage them to commit their support sooner
Old 23-04-12, 02:24 PM   #113
speareig
Junior Member
any chance of putting my name down for a set of non scottoiler or is it too late
speareig is offline   Reply With Quote
Old 23-04-12, 02:29 PM   #114
muzikill
muzikill's Avatar
You should really do some spares just in case. btw lance look at the amount of views.
Old 23-04-12, 03:23 PM   #115
i've heard some excuse in my time for dodging the bar buttttt
starting to think that... might invest some spare cash and give ebay a try
Old 23-04-12, 03:31 PM   #116
No..Name................Type............ Post to
1...joshwalker094.......Non-Scottoiler (Post to Nobbylad)
2...DarrenSV650S........
3...Epic Monkey.........
4...MJC-DEV.............Non-Scottoiler
5...Nobbylad............ (Post to Nobbylad)
6...muzikill............
7...The Guru............Non-Scottoiler
8...The Guru............Non-Scottoiler
9...fluffer.............Non-Scottoiler
10..Kilted Ginger.......
11..Turner..............
12..Jayneflakes.........
13..SIII................
14..peterco.............
15..tetol...............
16..twinset.............Non-Scottoiler
17..Davy.h..............Non-Scottoiler
18..Speedy..............Non-Scottoiler
19..Shawthing...........Non-Scottoiler (Post to Nobbylad)
20..Sputnik.............
21..Elliott Woodruff....Non-Scottoiler (Post to Nobbylad)
22..Steve_God........... (Post to Nobbylad)
23..SirBarnz............Non-Scottoiler
24..federer.............
25..originlabs..........Non-Scottoiler
26..Artful..............
27..Speedyctr...........Non-Scottoiler
28..ImplodedHamster.....Non-Scottoiler
29..Soulkiss............
30..whistler............
31..AkiraSV............
32.. Beetrootkiller
33.. SV..al...non scottoiler...Anglesey
34.. CodeJACK............Non-Scottoiler
35.. Aidan........
36.. speareig............Non-Scottoiler
done..
anyone looking and thinking about buying you have a few weeks before they are done. once i get them cut then its the weekend of that same week they will be ready.
i will stress now that if i get more done and they go on ebay the price will be higher
Lance
Old 23-04-12, 04:02 PM   #117
Nobbylad
Nobbylad's Avatar
I reckon you should look at 50 for your first run, you're bound to shift a few via ebay/SVRider.
As for dodging the bar, I will gladly buy you a pint when you're next in the North West of England, in fact, if you hand delivered the plates, I'd buy you two pints
Old 23-04-12, 07:12 PM   #118
lazymanc
32.. Beetrootkiller
35.. Aidan........
37. lazymanc..........Non-Scottoiler
Cheers!
lazymanc is offline   Reply With Quote
Old 23-04-12, 07:27 PM   #119
Dave20046
Dave20046's Avatar
I'd be after a non scottoiler one depending on cost
Old 23-04-12, 07:36 PM   #120
someone hasn't read the thread
they are £12 a pair Dave...
saying that it all depends on how i get on this week with the laser cutters. if i can get a good price out of them then i will gladly drop the price for everyone. as i said at the start i'm not out to make profit from org members out of this i'm doing it because i can.
Lance
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
