Old 02-11-09, 11:04 PM   #21
smdoyle
Default Re: Indicators
Check the wiring configuration by searching this forum for 'flash-it relay' or 'led indicators' and you should find some more info.
Just found this thread: http://forums.sv650.org/showthread.php?t=84870&page=1
Old 03-11-09, 03:08 PM   #22
wow
Originally Posted by smdoyle View Post
The fronts require indy spacers which are £4.99 from Motrax, or most bikes shops: http://www.motrax.co.uk/index.php?mo...uct&id_prd=164
Is that for naked and faired ones? Mine is naked.
Old 03-11-09, 04:37 PM   #23
smdoyle
You only need indy spacers for faired bikes.
Old 15-11-09, 04:57 PM   #24
wow
Nope needed both pairs of spacers, one for the front and one for the rear (tail tidy). This is because the stock indicators are larger and use 2 holes in the bike, the smaller indicators only use one hole so you need the spacers to cover the second hole
They were cheap only £4.99.
Old 15-11-09, 05:10 PM   #25
Lozzo
Every time I've needed to modify a bike fitted with fast flashing LED indies I've found the Bike-It relays for this job just plug ino the socket in place of the original and do the job as required. Last one I did was on an 02 plate R1 fitted with some tiny little LED indies that used to flash faster than I could count in my head. The Bike-It LED relay calmed them down enough to sail through the MOT.
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
Led Indicators H62 Bikes - Talk & Issues 6 17-03-06 04:56 PM
LED indicators 650newb Bodywork 7 28-02-06 05:42 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
