#11 | |
You're quite welcome - that's what we're here for! That's the good news, the bad news is that from what you relate I suspect the lifter has shuffled off it's mortal coil. A new one, part number; '23200-11D00 Clutch Release Screw' is about £45, see here: Click me! There remains the possibility that the lifter has simply lost it's bearings, (did you see what I did there? ![]()
#12 |
Sid - you're a true gent. 'Lost its bearings' - I like it, also thought the mortal coil bit sounded like it should have been a pun.
Think I'll do more harm the good if I try and replace the balls so I'll get a new one - won't arrive for at least a week though so I'm going to tinker with the adjustment and hope I can get to Galway and back with it. It's pretty much all motorway and dual carriageway though so won't be using the clutch much. Apart from getting on and off the ferry of course - but what's the worst that could happen?! |
Clutch Cable Adjuster | RichT | Stuff Wanted | 1 | 22-11-11 07:05 PM |
Clutch cable top adjuster | Stonesie | Stuff Wanted | 3 | 02-01-11 09:17 PM |
Clutch Cable adjuster - where from? | warrenhewitt10 | SV Talk, Tuning & Tweaking | 12 | 02-09-10 10:30 AM |
Longer Clutch Cable | shelleyamy | SV Talk, Tuning & Tweaking | 9 | 04-11-08 08:38 PM |
clutch cable adjuster | kwak zzr | Stuff Wanted | 4 | 30-01-07 05:11 PM |
