Old 01-05-10, 08:35 AM   #1
Taipan
Taipan's Avatar
Question Rattle at 5-6k under load?
Hi All
Just been out on my Sv for the first time in a month. The bike has sat unused during this time. I gave it a handful of throttle and noticed a pronounced rattle between 5-6k? It sounds like its coming from teh front of teh engine but can't be 100% sure?
First time I've ridden it without a race can on so I suppose it could have been there longer? Any ideas on what this could be?
If its he cam chain can you reset the tensioner? How much are new ones?
Many thanks
Old 02-05-10, 10:31 AM   #2
jacksuzukisv650
Default Re: Rattle at 5-6k under load?
how many miles bike done ?
Old 02-05-10, 12:43 PM   #3
jonny.boyd
jonny.boyd's Avatar
i've had this pop up on mine now and again. Seems other people have too:
http://forums.sv650.org/showthread.php?t=150623
jonny.boyd is offline   Reply With Quote
Old 02-05-10, 01:11 PM   #4
Holdup
probably cam chain tensioners, is yours a pointy or a curvy? curvy ones can be reset and a popular mod is to fit the tensioners from a 2003 pointy model to the curvy as they auto adjust so to speak
Old 02-05-10, 01:57 PM   #5
Taipan
Taipan's Avatar
Just under 30k.
At least I'm not alone with it then!
Mine is a curvy. Looks like I'd better research how to reset it. What a time to go I had someone coming to look at it too. Typical
Old 02-05-10, 03:02 PM   #6
Holdup
I think theres a guide some where on the forum how to reset it, the home page i believe
Old 02-05-10, 09:39 PM   #7
Taipan
Taipan's Avatar
Interesting?
http://cgi.ebay.co.uk/Suzuki-Sv650-M...item19bbe1b675
Old 04-05-10, 09:48 AM   #8
Taipan
Taipan's Avatar
Found the post below ad will try that this weekend. Is it as easy as it sounds? Anyone else done this? ANy reason why i shouldn't do this?
to reset you don't need to remove the tensioner itself.
take the central bolt out, using a small electrical screwdriver (careful not to damage the thread for the bolt), incert it and you'll feel it engage with a slot (you can't see it), turn the screwdriver clockwise (as in doing up a screw), you have to hold tension on it as it retracts the plunger against the spring inside, once it won't turn anymore, "sharply" withdraw the screwdriver and the plunger will "flick out" to the right length.
and that's al that is required, it's worth doing this at service time anyway as it keeps them from seizing up.
Cheers Mark.
Old 04-05-10, 02:28 PM   #9
Best bet as per the thread jonny posted drop the oil firstly and see what happens
Jonny did that do the trick on yours btw?
Old 04-05-10, 06:54 PM   #10
jonny.boyd
jonny.boyd's Avatar
Haven't had the chance to do it yet.
Infact i'm feeling rather lazy, i'm seeing spannerman soon so he's gonna do me a service at the same time as other bits and bobs. Can't be bother wasting oil and time when it's just gonna be done again in a few weeks.
Will post what the bike feels and sounds like after that.
New K8 rattle mustnt grumble SV Talk, Tuning & Tweaking 15 13-04-09 09:55 AM
What's this rattle northwind SV Talk, Tuning & Tweaking 10 07-05-08 06:42 PM
Rattle? barmy.biker SV Talk, Tuning & Tweaking 8 30-11-07 07:49 AM
Odd chain rattle... Stingo SV Talk, Tuning & Tweaking 4 14-03-07 10:24 PM
Rattle above 8k on tacho TSM SV Talk, Tuning & Tweaking 0 12-08-05 11:33 PM
