#51 |
Captain Awesome
ok, some maths, because everyone loves maths...
what's that? only me? oh well then..... 530Hz = 530 cycles per second therefore each cycle is approximately 1/500th of a second = 0.002 seconds to initiate a 180 phase shift, you would have to have one horn sound while the other is at exactly one half cycle, so that's a time delay of 0.001 seconds (half of 0.002) at the speed of light, the current will cover 3x10^6 metres in that time, so one wire would need to be 3,000km longer than the other. this is all beside the point though, the actual horns themselves would need to produce the exact same tone, at exactly the same delay from when the current flows into the device, which isn't going to happen in real life
Official "Dumbass of the Year" 2011 (•_•) ( •_•)>⌐■-■ (⌐■_■) Deal with it... |
#52 |
You've got some pulsing in the charging system too... don't forget that!
Anyway, the twin stebels are a different frequency anyway when you buy a "left" and "right" pair, so it's a moot point.
#53 | |
![]() Come then, out with it. ![]() |
#54 |
Captain Awesome
i never claimed to know what caused it, i just showed that it would be impossible for changing the length of the wire to cause the effect you describe
![]() keep pitching ideas and i'll offer my opinion on whether they're realistic ![]()
#55 | |
How's about you come to NW and I'll open the bike up, we can try different lengths of wire until you're satisfied? ![]() |
#56 | |
Captain Awesome
apparently not, otherwise the situation would have yielded the same result...
#57 | |
I thought you'd assumed that the sound is produced the instant the electron reaches the pump... ![]() You did tell me though, that all I needed was a 0.001 second delay in the sound coming from the air chamber on the magnum to achieve the effect I described. |
#58 | ||
Captain Awesome
if anything the time that the motor needs to spin up and begin compression is a MASSIVE opportunity for variation in the delay in the voltage being applied to the horn and the sound emerging, variation that would completely mask the effectively zero difference from changing the length of the wire which you seem to think is the cause Quote:
![]() no, i said that in order for two waves of frequency ~500Hz to form destructive interference they would need to be 0.001s out of phase, they would also need to exist in a theoretical world where the two waves are emitted from the same point source. in the real world this is nothing like the case, both of your ears would have to be an integer number of wavelengths from both sources, you would have to account for echos within the horn mouth itself and around the bike, in the garage etc. sorry, but it's nowhere near as simple as you think it is
#59 |
You took a long long time to write that.
![]() I know what I witnessed, and what I changed. Why do I need to impress anyone? I spent a good couple of hours head scratching, wondering why there was no sound when both horns had current passing through them, the button was pressed many many times, thereby ruling out motor spins/charging rate from the equation - if that were the case, one of the horns would of gone back to the shop, and it's a factor I considered whilst playing with the DMM. Again, the only thing that was changed was the length of one of the wires, and one blue spade connector. Throw theory at me all you like, I've physically done it. I know of other .Org'ers that have expierenced similar issues (namely one that had the exact same issue, and another that had a horn that sounded "like a flat cow fart"). Again, those issues were with multiple horns on the same frequency, and the lengths of wire were changed to correct the issue. NB, not that it makes much difference, but your maths is for the lower tone of the nautilus, whereas my horns are Magnums. But then, we're only talking a couple of hundred megahertz at best. Last edited by Baph; 30-07-08 at 07:25 PM. Reason: spelling |
#60 | |
Captain Awesome
L.E.D Relay | stevo_sv | SV Talk, Tuning & Tweaking | 9 | 17-06-09 08:39 PM |
Horn Relay | James SV | SV Talk, Tuning & Tweaking | 13 | 01-05-09 07:55 PM |
HELP!!!! led relay | ashb1878 | SV Talk, Tuning & Tweaking | 0 | 22-11-08 04:20 PM |
Led Relay | bryanmurr | Bikes - Talk & Issues | 5 | 22-10-08 06:03 PM |
starter relay | anna | SV Talk, Tuning & Tweaking | 2 | 14-11-05 02:10 PM |
