Old 25-11-08, 05:35 PM   #1
stevo_sv
Post L.E.D Relay
To put it simple im in need of a L.E.D relay for the sv.
im being told that the Suzuki relay is different to the 'universal' relay other manufactures use, and from what i've found so far, they're stupid money.
so does anyone know of a site etc that sell them without a stupidly high price for what is basically a coil of wire and the use of magnetic flux? .
cheers steve
Old 25-11-08, 05:45 PM   #2
Default Re: L.E.D Relay
If you get one from halfords (think its a honda one) you just need to adjust the wiring slightly for it to work. Cheap as chips.
The info is on here because that is where I got it. Have a search
Old 25-11-08, 05:48 PM   #3
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
lies...
use universal motrax flash it relay and it'll work fine, mine's installed right now
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 25-11-08, 10:06 PM   #4
transparent_opacity
Is this for indicators? I've fitted 2 resistors under the rear seat to bring the resistance up across the 4. 20 min job, cost a few quid. Details are on this forum if you search...
Old 11-06-09, 08:35 AM   #5
boo86
what size resistors did you use ? I tried 100 ohm last night and they didn't flash at all. I think it was too much.
Thanks,
Old 11-06-09, 08:38 AM   #6
ophic
ophic's Avatar
The resistors are normally wired in parallel so actually reduce the overall resistance. The problem is that the resistance of LED or low wattage bulbs is actually too high. Hence the fast flash when a bulb blows (infinite resistance).
Silver SV650SK3, Fuel exhaust
Old 11-06-09, 08:45 AM   #7
SoulKiss
SoulKiss's Avatar
And the other problem with resistors is heat.
They work, and they probably wont cause you a problem, but the relay is a much better solution.
█╬╬╬╬(•)iŻi▀▀▀▀▀█Ξ███████████████████████████████)
Old 11-06-09, 08:57 AM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
They do get rather hot.
I've got a motrax universal relay to fit at some point when i get around to it
2011 Speed Triple 1050
Old 17-06-09, 08:22 PM   #9
transparent_opacity
I don't know off the top of my head, but I used the size recommended elsewhere on this forum.
I've had *no problems* with heat, they barely get warm.
Old 17-06-09, 08:39 PM   #10
starks
iv got a motrax unit but got no idea how to wire it up
scrap that i just searched it on here and found out how to do it, woo hoo
Horn Relay DarrenSV650S SV Talk, Tuning & Tweaking 107 29-12-11 02:46 PM
HELP!!!! led relay ashb1878 SV Talk, Tuning & Tweaking 0 22-11-08 04:20 PM
Led Relay bryanmurr Bikes - Talk & Issues 5 22-10-08 06:03 PM
Relay Wiring Help ukhammy SV Talk, Tuning & Tweaking 33 22-04-08 09:38 AM
Starter relay Slim666 Stuff Wanted 1 25-07-07 10:16 AM
