Old 29-10-08, 10:26 PM   #81
Default Re: Horn Relay
in a pretty water-tight casing.
Aye but still smear it in grease.
Old 29-10-08, 10:45 PM   #82
Luckypants
Luckypants's Avatar
Vasoline (petroleum jelly) might be better in this case?
Old 29-10-08, 10:55 PM   #83
That'll do.
Old 29-10-08, 11:54 PM   #84
Cheers you lot
Old 31-03-10, 07:27 PM   #85
cbay
cbay's Avatar
Updated schema to show correct polarity for connecting the Stebel (in case your stupid enough to wire it the wrong way around...in which case it will sound like someone gently passing wind as opposed to a proper air horn.....now who could be SO stupid ? )
Nobbylad! Your a Genius! I printed off your diagram today and used it to refer to for my Stebel!
All fitted successfully.
I seperated my Stebel and put the one part in nose of fairing and the other part down behind radiator. I ran the cables back towards the seat and put the relay in there nicely tucked away.
Works a treat, I just want to go use it now. lol.
I was a little scared as I finished doing it all around 5:30/6PM and everyone was walking past, so I think I scared one or two people whilst testing it all worked.
Old 31-03-10, 08:39 PM   #86
Nobbylad
Nobbylad's Avatar
Not me who's the genius, Baph (aka Dave) and others did most of it, I just put it in a picture so that dunces like me could wire it up!
I never separated my bits, but just bolted it to the rad mount....worked fine up until the Wirral Egg Run where it broke (prob because it was getting more or less full use for around 45 mins).
Glad you got it sorted though...they do wake people up on the morning commute.
Old 01-04-10, 08:16 AM   #87
cbay
cbay's Avatar
Fair enough! Well all working, I scrapped the old horn its ****e, will keep it as a spare incase I really need it when stopped
Otherwise I want to go hootin it everywhere, lol. My Horn that is.
Old 24-12-11, 01:20 PM   #88
musne
NOOB question, but can someone please explain what the FRAME stands for in this diagram??
Old 24-12-11, 01:27 PM   #89
DJ123
DJ123's Avatar
i imagine it is for the FRAME, using it as an earthing point for the stebel horn.
BMW F800ST
Old 24-12-11, 01:27 PM   #90
The metal stuff your bike is made from
It is connected to the battery's negative
L.E.D Relay stevo_sv SV Talk, Tuning & Tweaking 9 17-06-09 08:39 PM
Horn Relay James SV SV Talk, Tuning & Tweaking 13 01-05-09 07:55 PM
HELP!!!! led relay ashb1878 SV Talk, Tuning & Tweaking 0 22-11-08 04:20 PM
Led Relay bryanmurr Bikes - Talk & Issues 5 22-10-08 06:03 PM
starter relay anna SV Talk, Tuning & Tweaking 2 14-11-05 02:10 PM
