Old 11-06-12, 06:56 PM   #21
Paul the 6th
Paul the 6th's Avatar
Default Re: Baffled..... stuck baffle.
Turns out the brutalised baffle is attached inside the end... Do not succumb to peer pressure people. What stupid design as well! Knew I should have waited til tomorra, shiit like this always happens on a Monday!
Old 11-06-12, 06:57 PM   #22
Paul the 6th
Can't even stubby it because I can't get the end off
Old 11-06-12, 06:59 PM   #23
Bordtea
You tried spraying a shed load of wd40/similar in there?
Old 11-06-12, 07:01 PM   #24
Tom_the_great
Tom_the_great's Avatar
waiting for the "how do i get the end of my can off" thread
Tom! Cleaned more then ridden ! SV650S 10 Plate Pointy!!,
Black Tinted Screen!, Evotech Tail Tidy!, OEM Rear Hugger!, R&G Crash Bungs!, Delkevic Exhuast!
Current Mileage = 3000 (Ish)
Tom_the_great is offline   Reply With Quote
Old 11-06-12, 07:06 PM   #25
Paul the 6th
The end isn't riveted on, it's pushed in with a rubber sealing band round the edge, managed to get the end cap out about a 1cm at the bottom but the top is stuck solid.
Old 11-06-12, 07:06 PM   #26
Paul the 6th
Shall I bring it up?
Old 11-06-12, 07:08 PM   #27
Spank86
I still think fire or heat will be the answer. Fire usually helps.
Old 11-06-12, 07:09 PM   #28
Paul the 6th
just found a post from hovis years ago saying micron can's are a bitch to do might just push it all back together and ride around with a fcked baffle..
Old 11-06-12, 07:21 PM   #29
DJ123
DJ123's Avatar
i found another thread on the internet http://www.gixxer.com/forums/showthread.php?t=255211 looks liek there might be a small weld at the lip, preventing the baffle coming out if the screw was to fall out
BMW F800ST
Old 11-06-12, 07:23 PM   #30
Paul the 6th
cheers Job mate, really appreciate you having a look for me without me even asking. Just found these stubby can's on ebay for £109 but after firing the SRAD up without a can on it, if the super stubby was even half as loud as no can, it'll be too loud. Really tempted though
http://www.ebay.co.uk/itm/SRAD-GSXR-...item256767ab3e
Baffled drefraser SV Talk, Tuning & Tweaking 12 08-01-08 12:51 PM
baffled kwak zzr Idle Banter 13 03-11-07 06:53 PM
Baffled tomjones2 Bikes - Talk & Issues 2 03-06-07 06:37 PM
Baffle Stuck Full Throttle SV Talk, Tuning & Tweaking 9 23-03-06 10:24 PM
baffled by the baffle goldengraemes SV Talk, Tuning & Tweaking 5 20-02-05 05:18 PM
