#141 |
That's also pretty much what I do - maybe a little more exaggerated.
#142 |
#143 |
#144 |
#145 | |
![]() Any rev matching should be done as quickly as possible. The only thing slowing the process is an engine's time-to-rev, blipping isn't the step-by-step process you describe. On a fast revving bike, it all happens at virtually the same time, almost as quickly as you can get the clutch in and out. The only difference between the two things you describe is that you don't close the throttle at the end. If you were braking you would, and no one that was going to accelerate in the lower gear would ![]() |
#146 | |
#147 |
Blip Mwaaaaaaaah, blip blip mwaaaaaaah, brake & squeak (forgot to blip) Mwaaaahhhh, mwaaah. mwaaaaah, blip, mwahhhhh.
#148 |
Personally I don't blip when slowing, I just don't release the throttle when changing down. I blip at traffic lights, when I'm bored or to let other drivers know I'm there.
#149 |
#150 |
If you ever have to get a bike home with a broken clutch cable (pipe on a thou) you will be glad you practiced blipping the throttle.................
SV1000S K4, Hugger, Scottoiler. Lowers |
Blipping the throttle after changing down a gear. | Ruthja2801 | Bikes - Talk & Issues | 88 | 25-02-09 02:30 PM |
Is there a big disadvantage to not blipping the throttle on fast downchanges? | monkey | Bikes - Talk & Issues | 25 | 06-04-08 02:43 AM |
Braking or Blipping-which is right? | Peter Henry | Bikes - Talk & Issues | 58 | 27-11-05 09:11 PM |
Blipping - eh? | Halonic | Bikes - Talk & Issues | 23 | 26-04-05 03:56 PM |
Ineffective blipping! | BaggaZee | SV Talk, Tuning & Tweaking | 21 | 27-01-05 10:52 AM |
