View Poll Results: Is you tyre pressure
High 3 9.09%
Bang on 25 75.76%
Low 5 15.15%
Voters: 33. You may not vote on this poll
Old 03-05-06, 09:06 AM   #11
richwill68
Road Attacks at 36psi front 42psi rear. Checked once a week.
Old 03-05-06, 09:30 AM   #12
SVeeedy Gonzales
33F/36R
Run them a couple of PSI lower than that in cold weather though.
Old 03-05-06, 09:44 AM   #13
Warren
Originally Posted by SVeeedy Gonzales
33F/36R
why lower in cold weather ?
i run mine 34/40 (stock is 36/42)
but ive recently put them back to stock for some reason.
Old 03-05-06, 10:37 AM   #14
Skip
Skip's Avatar
33F/36R as per Richienumbers dads masking tape sticker under the seat - works for me!
Check them every couple of weeks, never seem to move if I use the bike regularly...
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 03-05-06, 10:40 AM   #15
Originally Posted by Nexus242
Originally Posted by northwind
My Roadtecs are sitting pretty at 36/39. Some run them harder, some run them standard, but this seems to work for me.
And what does running them that high actually do to you???
Stops the sidewall flex they can give you when you thrash them... And has no obvious ill effects. Should also increase lifespan.
Old 03-05-06, 11:43 AM   #16
SVeeedy Gonzales
Because they're D220's and the grip on cold and wet days is pants. They feel grippier to me with 2 psi lower, though that could just be down to feeling more confident about doing it than actually getting any more heat into them.
Old 03-05-06, 11:47 AM   #17
Fuzz
Mine are most likely slightly lower than they should be. I tend to forget to check before I leave the house, then when I stop for petrol I consider it pointless to check as the tyres have warmed.
Old 03-05-06, 11:56 AM   #18
GSXR Carlos
i normally run mine at 32/36 but i haven't checked in a while, i'll do it later on tonight
Old 03-05-06, 12:41 PM   #19
mysteryjimbo
They are, softer tyres have more contact area.
If you run tyres too hard you can run the risk of reducing the contact area. This would speed up turning but reduce overall traction
Old 03-05-06, 12:44 PM   #20
Blue_SV650S
Must admit I am really slack when it comes to checking my pressures routinely … therefore I have no idea what pressures my tyres are at!!! … To be honest when I last pumped them up I didn’t know what the recommended settings were … so pumped them to what I thought was ‘about right’ at the time!!!
I also have a mismatch of tyres … an Mez3 on the front a Pilot Race (170 section) on the rear … its all good!!
So in shot I don’ really check or care, but I feel I’d soon know if something was seriously amiss!!
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
How much?(tyre pressure) Jussi Tyres 4 26-07-07 08:07 AM
Tyre losing it's pressure thedonal Bikes - Talk & Issues 10 27-01-07 03:12 PM
FRONT TYRE PRESSURE................ alexb SV Talk, Tuning & Tweaking 12 23-01-05 04:39 PM
Tyre pressure? Rodger Wabbit SV Talk, Tuning & Tweaking 10 24-11-04 12:23 AM
