Old 20-11-07, 06:42 PM   #11
Default Re: tank raisers
Fair enough, will see what happens, need a dyno run or 2 anyway to make sure my own bodgy restrictor kit works
on a complete tangent, has your post count gone around the clock?
Old 20-11-07, 07:21 PM   #12
Razor
I raised my tank 20mm and removed the foam on the underside. I've drilled the carb slides and jetted up a bit, I've enlarged the inlet of my K&N filter, due to it being kinda small to start with. Bike makes nice noise with bitsa exhaust.
Old 20-11-07, 08:01 PM   #13
I've been clocked by an unscrupulous dealer for easy resale
Old 20-11-07, 09:01 PM   #14
carb slide driling is on the list too, like I say will see how it goes when I get it on a dyno.
Old 20-11-07, 09:57 PM   #15
hovis
carb slide driling?
whats this all about?
Old 20-11-07, 10:01 PM   #16
the vacuum transfer port on the bottom of the carb slider ... you can enlarge it a bit so the slides raise quicker ... picks up a bit quicker
Old 20-11-07, 10:10 PM   #17
Robw#70
carb slide driling?
You enlarge the vent holes in the bottom of the slides, this increases the slide speed.
Good points:-
Allegedly increases throttle response
Bad Points:-
Causes the slides to 'Flutter' actually slowing them down, but like all good tuning mods its free and on the internet so must be good
As for tank spacers there's not a noticeable difference, certainly not enough to justify a jet change
Old 20-11-07, 10:27 PM   #18
hovis
have you got the R6 throttle grip?
Old 20-11-07, 10:29 PM   #19
Robw#70
No 41mm FCR's
Old 20-11-07, 10:30 PM   #20
hovis
Originally Posted by Robw#70 View Post
No 41mm FCR's
Tank raisers yorkie_chris SV Talk, Tuning & Tweaking 34 07-02-10 05:43 PM
DIY Tank raisers Lozzo SV Talk, Tuning & Tweaking 40 07-01-10 07:34 PM
tank raisers, are you aloud them trialspaul Mini-Twins 6 23-02-09 05:20 PM
Tank raisers - GONE - TOO LATE! Cloggsy For Sale - SV's and SV related items 17 19-02-07 11:23 PM
Tank Raisers redeye321 SV Talk, Tuning & Tweaking 10 29-05-05 10:52 AM
