Old 29-11-07, 03:19 PM   #11
Daimo
Default Re: Low Oil (pretty urgent)
Yes, i can assure you you don't want to run low...
Especially whilst having a top speed blat against a Hornet :look:
Old 29-11-07, 04:04 PM   #12
wheelnut
Originally Posted by gettin2dizzy View Post
I'd rather have too much than too little, put it that way.
Too much oil does as much damage as not enough, plus you will struggle to get any gears if you overfill it.
What you need to do is to work out the difference between min and max in the window
Old 29-11-07, 04:21 PM   #13
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Originally Posted by Daimo View Post
Oh, btw, oil should be checked when the engine is off, cold, and upright.
two out of three ain't bad
engine should be off and level, but you should do it after running up to temp then leaving for a couple of minutes to settle
so sayeth the manual
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 29-11-07, 04:58 PM   #14
sv-robo
+1
Old 29-11-07, 07:43 PM   #15
TEC
TEC's Avatar
Be the first one that does say that, it may say something like if the oil has been changed then run for a few mins to fill the filter and leave for a few minutes or if the bike has been run leave for a few minutes. But the best time to check the oil is when the engine is cold because then you will get a true level, it takes more than a few minutes for the oil to drain down into the sump, checking while warm can give a false reading, ie low, you add more thinking its needed and only discover the error later on
And if my mechanics have all been wrong about that little bit over 30 years then I must have been lucky
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Old 29-11-07, 07:58 PM   #16
the_lone_wolf
Captain Awesome
Page 6-14 of the K6 manual:
ENGINE OIL LEVEL CHECK
Follow the procedure below to inspect the engine oil level.
1. Start the engine and run it for a few minutes.
2. Stop the engine and wait 3 minutes.
3. Hold the motorcycle vertically and inspect the engine oil level through the engine oil level inspection window on the right side of the engine.
filter change is the next section, completely seperate
make of that what you will, but i'd say suzuki know how to check the oil on their bikes
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 29-11-07, 08:53 PM   #17
No, you're absolutely correct, the manual advice whilst not wrong is simply un-necessary. Plus there is the fact that oil will 'bulk up' when air gets trapped in it in use leading, possibly, to a false reading.
Hmmmmm...
Old 29-11-07, 09:12 PM   #18
rigor
Hmm, would this be the same Suzuki that put the oil sight glass in the wrong position on the first TL's
Old 29-11-07, 09:39 PM   #19
the_lone_wolf
Captain Awesome
fair dos to the nay-sayers, i'm off to the NEC tomorrow, but on saturday i'll test the theory by checking the oil cold then hot, see if they're the same, it would certainly be easier checking it without starting it...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 30-11-07, 10:02 AM   #20
petevtwin650
Oil can be kept for a while as long as you keep it in a sealed container (its bottle, then) and keep it somewhere dark and reasonably cool (so the garage or shed)
Matt
Haven't heard that before. Surely that's for distilled water?
Photo of pretty R1 Tallguy Photos 58 15-09-08 02:36 AM
Pretty in pink rictus01 Soho Massive 19 15-07-08 10:47 PM
That was pretty painless Lozzo SV Talk, Tuning & Tweaking 3 25-01-08 11:39 PM
limewire help please......pretty please hovis Idle Banter 17 20-12-06 03:30 PM
My new car, its pretty quick DanDare Photos 5 27-05-06 07:12 PM
