#11 | |
#12 |
How do you guys torque up the head nut on the pointy?
I need to grease the bearings and the manual says I need a 'special tool'. |
#13 |
just at it says in post 11 right above yours. Only 'special' tool required is a spanner.
#14 |
So, er, chisel Ok then?
I might have some c spanners achsully...pipe? |
#15 |
cunning plan develops involving a socket, a welder and some small bolts............
#16 |
You really ought to use a C-spanner if at all possible, one thing which rings warning bells to me is seeing castellated nuts which have been beaten with chisels etc. What else am I going to find?
The curvey SV is quite easy to get right by feel as the others say. Note that when you tighten down the cap nut on top of the yoke it will invariably tighten the bearing adjustment. If you can get the front wheel off the ground (or wheel out) it's much easier. I usually just lightly nip the bearing nut, then nip the cap nut gently, try it for feel, tweak the bearing nut as required, nip the cap nut further etc. Basically set it as tight as you can before you start to feel resistance, slight pre-load is preferable to loose. Pre-load they will tolerate, loose results in hammering and "brinelling" or denting of the bearings so they become notchy, then it's replacement. If they are too tight the steering will wander at low speed, then back off a touch.
#17 |
I had a little think after I mentioned chisels and realised that was a bit too cack handed.
I think I'll make a 'special tool' from an old 1/2" socket the same outside diameter as the 'diameter' of the inside of the nitches and weld some 'pins' to the socket that will fit the notches. |
#18 |
A castle socket is the correct tool.....
...although a c-spanner is the best alternative. |
#19 |
I uses a big nail with der pointy end ground off. Doesn't damage the stem nut anything like as much as a screwdriver or similiar. Still hardy a precision tool though, proper tools much better.
#20 |
With the curvey a C-spanner is better than a castle socket because you'll almost certainly need to tweak the bearing nut as you tighten the cap nut, you can't do that with a socket.
The C-spanner doesn't need to be very special, you're not going to be putting a lot of load on it, all the proper tightening is done on the cap nut.
Head Bearing problems | pete m | Bikes - Talk & Issues | 8 | 28-04-09 11:00 AM |
Crash.NET - Brivio, Romagnoli - head-to-head QA. | NewsBot | News | 0 | 02-02-09 05:50 PM |
Crash.NET - Rossi, Lorenzo - head-to-head QA. | NewsBot | News | 0 | 02-02-09 05:50 PM |
Crash.NET - Rossi, Lorenzo - head-to-head QA! | NewsBot | News | 0 | 02-02-09 02:50 PM |
head bearing nuts | kcowgergmm | SV Talk, Tuning & Tweaking | 4 | 12-08-07 02:07 PM |
