Old 12-03-08, 02:44 PM   #11
Grinch
Default Re: curvy throttle
You know I've been mubbling on about the clutch cable and not the trottle, but the loobing still applies, so ignore the worm drive bit. I had Jambo give me a hand with mine oiling it with a pressure cable oiler, it went from having a fixed cruise control throttle to one that was like a grease ferret, that had just had a bath in grease while skating on grease.
Old 12-03-08, 02:46 PM   #12
hlaf_lyfe
mine has the two cables as well, rekon chain lube is a good lubricant to use?
Old 12-03-08, 02:49 PM   #13
Grinch
Scotoiler oil worked a treat for us, but 'oil' point blank is better then nothing.
Old 12-03-08, 02:51 PM   #14
was jjust gonna say the same, anything you've got to hand I should imagine
Old 12-03-08, 03:11 PM   #15
Viney
The are 2 things on the curvy that makes the throttle heavy as it is very light. Lack of loobing, or damaged/worn/ungreased worm drive. So I would look at those first.
On the throttle...you sure about that?
A new cable is only ?11, ok its baout ?30 if you buy both cables. In reality, you only need the one and its the one with the tab.
Old 12-03-08, 03:14 PM   #16
embee
embee's Avatar
I like to use Halfords "Nylon&Rubber lubricant" for cables, comes in aerosol. I think it's now called "Silicone lubricant for rubber and plastics", same stuff.
Ideally disconnect the cable at the top end. Make a small funnel arrangement from tin-foil or similar at the cable outer, hold with a rubber band, then squirt some lube in and work it up/down. Many cable sare nylon lined these days, and it seems to suit the application well in my experience.
Old 12-03-08, 03:28 PM   #17
Grinch
I thought that was just for in the bed room...
Old 12-03-08, 03:42 PM   #18
ASM-Forever
Do the R6 throttle mod.
Then your bike is one step closer to greatness.
Old 12-03-08, 03:55 PM   #19
Grinch
The only way you can put a bike closer to greatness is by placing it near or under me.
Old 12-03-08, 04:03 PM   #20
Alpinestarhero
You all wrong. SV's can only be transformed from "good bikes" to "great bikes" by the fitting of a Givi Monorack matched with a Givi Topbox.
Oh yes
Matt
r6 throttle mod , can it be done on a curvy? gaz-sv650s SV Talk, Tuning & Tweaking 45 16-02-10 05:01 PM
Curvy - Plastic Casing round the Throttle? JamesMio Stuff Wanted 7 19-12-08 12:32 PM
2002 curvy throttle problems Nicky S SV Talk, Tuning & Tweaking 8 31-08-08 10:02 PM
Other throttle cables to fit curvy SV ? Stig SV Talk, Tuning & Tweaking 0 19-01-08 01:34 PM
Throttle Tube (curvy) jakeblues68 Stuff Wanted 1 24-04-06 09:41 AM
