Originally Posted by SoulKiss
zero chance of accidentally blinding someone (although as you have stated, these are to be wired into high-beam only, so less chance of that - unless when using the pass light)
Wired to main beam yes, but with a "primer" switch before that.
So the dash switch would have to be ON and using pass switch in daylight for the spots to come on.
The reason for using the dash switch as a "primer" is that the Angel Eyes have a ring surround which is currently LED (and white), but I'm looking to change that to a cold cathode tube.
The surround LEDs are meant to be wired to sidelights (always on for the pointy), but they'll only come on with the dash switch instead. Then a relay will activate when main beam is on to bring the fog/spot lights on.
