Old 02-09-08, 07:33 AM   #11
trouty
Default Re: Longer dogbones 41mm
hmmm... my curvy seems to sit quite low at the back, wonder if someone's swapped the dogbones? never even thought of it until i read this thread!
Old 02-09-08, 10:06 AM   #12
wow
Originally Posted by Dangerous Dave View Post
10mm is the max and optimum when lowering the entire SV, if you are lowering just the front
Just out of curiosity why would you want to just lower the front?
Old 02-09-08, 11:36 AM   #13
Dangerous Dave
Quicken up steering, also with a well set up front end it adds a bit more feel. You will need to fit new springs and oil to suit you before you do this.
Old 30-10-08, 09:04 PM   #14
jennycook
Hi
Is anyone able to advise how much lowering front by 10mm (assume forks/yokes only) and using the 40mm drop dog bones wil lower the seat height itself ?? I am considering a new naked sv650, want to not be tottering on my tip toes for a change!
Thanks
Jenny
Old 30-10-08, 09:16 PM   #15
wow
I'm afraid I don't have the answer for you. On top of lowering of the bike you can also get the seat lowered by taking out some of the foam, you can take out quite a bit. Or buy a new lowered seat directly from Suzuki.
After having ridden my bike for 6 months I have also raised the handlebars using bar risers (naked SV) this makes it easier for shorter people and you can touch the floor even better.
Old 30-10-08, 09:22 PM   #16
jennycook
Thanks WOW, If not too rude a question ... what is your height and inside leg ? PM me if you prefer !!! Be good to compare to my own...
I have a test ride set up for the weeke end , but of course this will be standard.
Jenny
Old 30-10-08, 09:23 PM   #17
wow
I'll PM you.
Old 30-10-08, 09:28 PM   #18
Dangerous Dave
As long as you lower front and rear together you won't have a real problem with the suspension, problem comes when you lower the front only as you put more weight on the poorly sprung front end.
I would advise on a better cut seat first though.
Dogbone dimensions? riktherider SV Talk, Tuning & Tweaking 14 25-05-10 05:33 PM
Dogbones Phaelok SV Talk, Tuning & Tweaking 9 02-02-09 01:24 AM
longer dogbones wow SV Talk, Tuning & Tweaking 63 14-01-09 08:35 AM
for sale - Longer dogbones lowering kit wow For Sale - SV's and SV related items 6 16-10-08 06:43 PM
dogbones weazelz SV Talk, Tuning & Tweaking 8 12-06-06 07:55 PM
