#11 |
Raw ADSL line speed is function of the signal attenuation over the phone line. The greatest impactor on this is distance from the exchange, but the quality of the wire joins, condition of the wires dry joints etc all affect the signal. Finally remember that cable runs are not as the crow flies, but may take a circuitous route from the exchange to your house - it is the length of the cable that counts.
Finally though, to answer the OP - if you get 5Mbps line speed with Tiscali you should get the same line speed from any other provider that uses BT's wholesale ADSL service. If you go with an unbundled supplier (i.e. your line is connected to the ISP's equipment at the exchange) you may well see higher line speeds as this will be ADSL2+ not ADSL. (most routers happily work with either.) However line speed is only part of the story, as what you perceive as 'speed' is actually throughput, the rate at which useful information appears on your screen - a lot of this depends on your ISP's own network, contention at the local exchange for backhaul, contention in the DSLAM(s) and so forth. Tiscali are known to not have the best of internal networks so you may see an improvement in throughput ( or 'speed') from a new ISP even if both use the same bit of BT kit to provide your service.
"Your Viffer sounds like it is raising hell! Spot on." - Witchery 17/4/08 ![]() Snow Plough Appreciation Society - Member #3 ![]() Last edited by Luckypants; 09-09-08 at 03:34 PM. |
#12 | |
You can check which suppliers are unbundled at your exchange here. Look in the table headed 'LLU Operator Presence'
"Your Viffer sounds like it is raising hell! Spot on." - Witchery 17/4/08 ![]() Snow Plough Appreciation Society - Member #3 ![]() Last edited by Luckypants; 09-09-08 at 02:51 PM. |
#13 |
I moved from NTL Virgin to sky same crappy speed but only a fiver a month cos I already have sky, thing I dont undestand is why can you have a HD signal coming from a sateleite 22,000 miles away an get a great picture but we cant use the same technology for t'internet ?
#14 |
You can get satellite BB stewie, but it is slower and very expensive. OK in the middle of nowhere, not so good when ADSL is less that £10 a month from some suppliers.
#15 | |||
![]() ![]() Quote:
Anyway, the answer seems to be 'probably not but maybe a little'. Good enough! |
#16 |
Yes. Any others?
#17 |
#18 | |
![]() however if you already have Sky TV, the full call / Broadband package is hard to beat IMHO. |
#19 |
Aaarrrggghh! I don't want more choice, I want less choice! The only reason I'm even looking into it is because we're bombarded by junk mail from Sky, BT, Virgin, Pizza Hut etc saying we could be getting more for less. I just want it to be over!
Well, not Pizza Hut, but all the others. |
#20 |
Tiger, I have sky max.
Have had no problems with them. Current speed at 18 19 hrs ![]() pete
SV650 Sport in Black MZ saxon tour 301 Previous bikes SV650 Naked BMW 650cs Scarfer MZ RT 125 4 stroke |
Riding at 'high' speeds? | Magnum | Bikes - Talk & Issues | 74 | 21-02-09 01:24 AM |
cutting out at low speeds | ged | SV Talk, Tuning & Tweaking | 3 | 29-04-08 05:16 PM |
cutting out at low speeds | ged | SV Talk, Tuning & Tweaking | 3 | 29-04-08 09:14 AM |
gears used at different speeds | richbeales | SV Talk, Tuning & Tweaking | 31 | 10-10-06 11:53 AM |
SV gearing & speeds | TSM | SV Talk, Tuning & Tweaking | 9 | 14-06-05 08:59 AM |
