Old 24-07-09, 11:23 PM   #11
appollo1
appollo1's Avatar
Default Re: Drunken ebay purchase - oops
Stebel Nautilus is an air horn and WILL overload your horn wiring without a relay. Fit a relay and save your wiring, it's really not hard at all.
It is hard when like me I have no idea what you mean by or how to fit a relay.
I would rather not attempt it in case I messed up and caused a lot more damage and expense to fix.
i'm not old i'm experienced!!
http://www.german-shepherd-rescue-scotland.org.uk/ everyone deserves a second chance
RIP Appollo miss you and will always love you x x x x
appollo1 is offline   Reply With Quote
Old 24-07-09, 11:43 PM   #12
walkaboutandy
I have a Stebel Magnum with no relay (instructions said you didn't need one) and that works fine but the Nautilus comes with a relay and is apparently much louder then the Magnum (therfore must use more current).
The webshop I bought my horn from has some fitting instructions for the Nautilus too......albeit for a beemer.
http://www.nippynormans.com/STEBEL-N.../STB-NAUT-COM/
Old 24-07-09, 11:50 PM   #13
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
The nautilus is a completely different design to the magnum, and will draw ~20A when activated
Wire it directly to the battery and switch it with a relay, or you will almost certainly damage your SV's wiring...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-07-09, 08:16 AM   #14
Blue Flame
Blue Flame's Avatar
I have that horn on my bike. Prob got the instructions somewhere but I could bring me bike up and show you how where i fitted it if you want
Triumph Sprint GT 1050 -Sexy Phantom Black; Powerbronze Screen
Previous >> K3 SV650S - Candy Copper;Lower Fairing Set;Fender Extender; Powerbronze Screen; HEL Braided Lines;
Blue Flame is offline   Reply With Quote
Old 26-07-09, 10:43 AM   #15
appollo1
appollo1's Avatar
Thanks Blue Flame. I am in no rush to fit it so will no doubt catch up with you at some point - unless you want a wee run out sometime and are heading my way and want a brew!
Old 26-07-09, 04:49 PM   #16
-Ralph-
Drunken ebay prurchase my foot! Go on - admit that you just wanted a bigger horn!
Old 26-07-09, 05:11 PM   #17
shifter
I stuck one on my Daytona. Space was a problem, but if you look you can seperate the horn (plastic bit) from the compressor. You can then link them together with a length of hose.
This ment I could fit the compressor under the pillion seat and the actual spout is at the front of the bike.
I also used the relay but fitted the whole thing in such a way that i didn't alter the bikes original wireing at all. The holw thing can be put back to standard in minutes.
Old 26-07-09, 05:18 PM   #18
the_lone_wolf
Captain Awesome
how did you do this mate? trying to find somewhere to stick this on the ADV and i'm worried i'm going to break it. is it just a case of pulling the two tabs back and smacking the compressor tube out of the horn assembly?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-07-09, 08:25 PM   #19
I bolted mine to the side of the radiator with a bit of metal and wired it directly to the battery using a relay and in line fuse. I can pop over and give you a hand if you want
Old 26-07-09, 09:22 PM   #20
shifter
If I remember corectly, there are two plastic tabs that hook over some metal luggs on the compressor. You need to carefully bend the tabs clear of the luggs then the two halfs just pull apart.
Once you have the two parts you need some hose to join them together. The plastic half has a female and the compressor has a male conection.
Halfords stock a plastic hose conector, you will need to glue one into the hole in the plastic part so you have a male at both ends to push the hose over.
As I said I have the compressor mounted in the tail and the horn at the front of the bike so the hose I used to join the two runs the entire length of the bike.
It is still f**king loud!
Drunken Safari ASM-Forever Photos 6 06-08-07 10:16 PM
Your dumbest Ebay purchase to date haggis Idle Banter 18 10-05-06 08:24 AM
A Drunken President Bush Anonymous Idle Banter 2 28-01-06 08:38 AM
