Old 03-09-09, 02:49 PM   #11
ophic
ophic's Avatar
Default Re: A few brake queries
Pads are a taste thing, and the thing about them knackering discs is in dispute too.
Perhaps "my brakes were shagged, so I fitted HH rather than service them" comes in to it!
Do HH or sintered pads require a little more warming up time as well?
I do mostly motorways so every time I use my brakes, they are always stone cold.
Silver SV650SK3, Fuel exhaust
Old 03-09-09, 02:54 PM   #12
Brettus
hmm thats a good question that may have a bearing on my choice, as I say I'm not aggressive on mine so they are cold too mostly.
Old 03-09-09, 03:25 PM   #13
fastdruid
fastdruid's Avatar
I found the EBC's needed a bit of warming up before they bit.
Druid
Old 03-09-09, 04:13 PM   #14
Dave20046
Dave20046's Avatar
Yeah, that's what I'd been told.
I use HH's and after a complete service of the front brakes on the curvy the stopping was amazing.
I like ophics if it ain't broke attitude, but if you are going to be doing them; if I was you I'd get the stainless hoses. They're about £45 - £55 with s/s fittings IIRC.
As to whether you need to service the calipers; I think a few members routinely do it a few times a year tbh I do it when somethings up (probably not the best approach). First one was a bit daunting but all good once you have a reasonable idea what you're doing. Anyway if you think the brakes are ok; when you change the pads you want to check the piston movement, make sure they aren't seized (also check your pads haven't worn grossly unevenly). I do this by (this is disputable wait until someone clever comes along with a better method!) leaving the old pads I'm about to bin in the caliper and putting a big flathead screw driver between the pads and push the pads back to make sure the pistons can move ok. If they are seized solid or your seals are in a mess/jammed/half out whatever it may be time for a service. (checking the pads and piston movement is one of your servicing points btw).
For brake maintenance you need brakefluid, brake/carb cleaner and copper grease mainly. For the service you'll also need red rubber grease and a big bottle of fluid and ideally replacement seals.
Old 07-10-09, 09:13 PM   #15
Dave20046
Dave20046's Avatar
Right my turn for a question for the clever lot:
My brake seals need doing: Is it worth parting with near £50 for the complete kit (including bleed nip covers & sliding pin rubbers) or would just the £20 for the piston seals & dust seals suffice? Previously I've just gone with the latter, wondering if I was correct.
Old 07-10-09, 09:28 PM   #16
7755matt
Unless the other rubbers are crackered then just get the £20 piston seal kit
Old 07-10-09, 09:45 PM   #17
Dave20046
Dave20046's Avatar
Cool - ta matt
Old 08-10-09, 02:28 PM   #18
Son of a beesting
Where can you get just the piston seal kit?
My bike is only 2 years old as well but I think it might give the brakes a clean as I intend to commute through winter
Old 08-10-09, 02:32 PM   #19
Alpinestarhero
try wemoto?
a brake overhaul before winter is a great idea. Get some red rubber lubricant for the pistons and remember the neverseize / copper slip for the pins, backs of pads and bolts!
Old 08-10-09, 02:33 PM   #20
You don't need a seal kit (unless they're leaking), you can service them without replacing seals.
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
Naked Curvy with GSXR Suspension Adjustment Queries Ter SV Talk, Tuning & Tweaking 3 08-09-06 05:39 PM
Insurance queries Fizzy Fish Bikes - Talk & Issues 0 22-06-05 01:35 PM
Top Box and Security Queries E-Type Carrot SV Talk, Tuning & Tweaking 54 09-11-04 08:29 AM
