#11 |
A point on curvies and carb icing, a UK spec 'curvy' is fitted with carb heaters that should prevent carb icing. There is a problem though in that the sensor quite typically ends up resting on the frame, in the slightly warmed air from the rad or just in a still air pocket that is slightly above ambiant. Just make sure the sensor is in the cold airflow and there should be no problem.
I had a few problems with carb icing, moved the sensor slightly and didn't suffer again. The 'pointy' FI SV will be slightly better than the carbed 'curvy' in cold weather but I didn't have a problem using a curvy every day down to very fscking cold (-5 one day). Never failed to start. Grip OTOH is another matter. ![]() I notice someone says the SV is easy to bump start, well it is but not if the road is icy!! If you do plan on riding all year I *STRONGLY* advise to get heated clothing, best bike related purchase I made for all year round commuting, *especially* on relatively high speed A road/motorway commuting. Makes the difference between gradually loosing heat and actually being warm. I would also say go for the 'S', the fairing makes quite a difference at keeping some of the cold air away. Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#12 |
SV easy to bump start? I beg to differ.Unless you have a hefty helper to push,or a nice hill to roll down an SV is a helluva struggle to bump.
#13 |
For some info about the DAS, the module 1 test is on youtube for you to watch!
http://www.youtube.com/watch?v=ZwYsMajnlRY I passed it not long ago without seeing it, and it wasn't bad at all. Your instructor should prepare you well for it. |
#14 |
I passed my DAS is March. I did my CBT and DAS all within the same month and had never even sat on a bike before I did my CBT! The only advice I can give it to jump straight on that 500cc and get the test over and done with. I'd think that riding for a week or so out on your own will pick you up some bad habbits, I know I picked up some habbits very quickly after passing!
I ended up with 3 minors in the end, can only remember what one of those was about tho... And that was when I went straight over a roundabout, Obviously you dont signal at first but when you turn off, then you signal! I didnt do it, but its not serious. Just pretend he isnt there and ride safe. Oh and do exactly what he says, that helps. |
stupid questions | SuzukiNess | Idle Banter | 6 | 01-12-08 02:14 PM |
Stupid Questions | lily | Idle Banter | 28 | 30-08-08 08:14 AM |
Noob with stupid questions | MeatSwinger | SV Talk, Tuning & Tweaking | 1 | 03-02-08 11:47 AM |
Stupid questions about riding in Ireland | northwind | Bikes - Talk & Issues | 12 | 13-08-07 04:18 PM |
newbie and a few questions | rs_tubby | Bikes - Talk & Issues | 5 | 25-05-07 10:56 AM |
