#11 |
#12 | |
The forks will most likely have twisted in the yokes. You can just loosen the yokes and twist the wheel back straight while someone holds the bars for you. I did it alone so I tie wrapped the bars to the mirrors in the centre position, tie wrapped a laser level to the front wheel rims, and ran a string under tension from the back wheel to the front garage door, directly under the centre of the front wheel. When the distance between laser dot and string was the same 1ft in front of the bike and 10ft in front of the bike, the wheel was straight. Don't loosen the clip-ons, they will hold the weight of the bike whilst your yokes are loose. A new nose cowl is £171 +VAT from a Suzuki Dealer. I can now get them off and on in 20 minutes flat so let me know if you need help. You need to get the existing one off and see if the front cowl brace (metal frame underneath) is bent. Indy's are about 20 quid. Bar end is just the bolt inside that is bent, take it out and straighten it in a vice. My gear lever is just filed flat, and drilled and tapped with a bolt thru it at the moment, it works fine. Those things would get your bike back on the road. My bars hit the tank too and I have dents, it's because you have bent your bar ends back, that they are then able to hit the tank, nothing wrong with your yoke stops. Post up some pic's. So next weeks ride-out on a Lambretta, or are you going to try and get it roadworthy, or won't you make it? Last edited by -Ralph-; 11-10-09 at 06:27 PM. |
#13 | |
![]() I dont have clip ons, i done a bar conversion, i think the bars might be slightly bent but gonna check everything tomorrow. Thanks everyone for your messages, it means a lot ![]() Phil |
#14 |
Glad your ok Phil & the bike not too badly damaged, hope you get things sorted and back out riding soon to re-build your confidence. Good on you for getting back on & riding home too.
![]() As Pete says, we all make mistakes, put this one down to experience. |
#15 |
Edited for you dave lol
#16 |
Ahhh man. Glad you are ok. You didn't need to take the rideout so seriously that you had to go and test the tarmac. Good luck with fixing the bike.
#17 |
Glad to see you're OK - yoke's a basic problem to fix just loosen the clamps and use a wall or something as leverage to straighten it all back up.
#18 |
1. glad to hear your ok
2. ![]() im gonna crash like an a*** next week sometime, aren't i? |
#19 |
Glad you're okay mate! Hope your not too hurt.
I found 20 miles with no gear lever a pain let alone 70 miles! Last edited by jamesterror; 11-10-09 at 07:21 PM. |
#20 | |||
I just shat myself when i seen the armco approaching ![]() Just a bit of back ache, well lucky really considering i hit the kerb, kerb was ok though lol Just copying you James, didnt want you having all the attention. |
For Hovis-Gid-Stretchie-Wideboy , just a special thought for you guys on this special day | xXBADGERXx | Idle Banter | 21 | 24-07-09 04:26 PM |
Not a 33bhp anymore!! | panosm | SV Talk, Tuning & Tweaking | 4 | 18-04-09 06:16 PM |
Ah, They Don't Do Christmas Songs Like These Anymore | Lissa | Idle Banter | 10 | 12-12-08 09:45 PM |
Not naked anymore. S mirrors? | Razor | SV Talk, Tuning & Tweaking | 4 | 14-10-06 02:18 PM |
She's Not Naked anymore! | Richie | Photos | 8 | 18-03-06 12:58 AM |
