Mini-Twins Goto Minitwins Official Site
Old 29-11-09, 11:17 AM   #11
suzuki139
Default Re: High compression piston kit
No but I don't think going long-stroke would be the best thing for them.
Why don't they just check like in F1 pylon racing? Fill cylinder with oil and measure volume.
chris that would be to much work for them...
Old 29-11-09, 11:20 AM   #12
So instead they remove head and measure bore?!
Old 29-11-09, 12:14 PM   #13
suzuki139
that would be correct chris..
Old 06-12-09, 01:06 PM   #14
coxxy
Be careful lads and dont waste your precious pennies. Minitwins have strict limits on output (72 BHP) and at Bemsee for example you can expect to be put on the dyno at regular intervals throughout the season. It has been known for protests to be put in, so you could lose any credibility if caught cheating as well as disqualification from rounds current, past and future. Of course if you want to play around with the power weight ratio then off to thunderbikes for you.
The SV block should make 72 BHP comfortably with a race can and system (legal), ecu or power commander and mapping (legal) and race filter (legal). It doesnt need mechanical tampering. Or cheating.
Of course you could also try and be a better rider, or get your suspension set up bang on, or even buy some nice sticky tyres (all legal)
coxxy
Old 06-12-09, 01:13 PM   #15
Who says he is in minitwins?
Old 06-12-09, 01:43 PM   #16
weecorey
coxxy
I race supertwins in Ireland, no BHP limit just 650cc. Wish it was limited to 72BHP as it would be a hell of alot cheaper!
I know I'm not in Minitwins, supose he reckons I am because of the catagory the thread is in, should make it an SV racing catagory to cover every one.
Old 06-12-09, 05:16 PM   #17
coxxy
so are we agreed then the minitwins thread is for......................minitwins?! Not that I mind at all but: Just so we dont confuse the rooky readers?
Old 07-12-09, 07:53 PM   #18
weecorey
Got the bike on the dyno today, wanted to get a figure before I do any work so I know what i'ved gained when I'm finished, at the minute its 73.1 BHP, the guy who done it built another engine in the supertwins which is putting out 89BHP! If I can get 80BHP when I'm finished I'll be happy
Old 07-12-09, 08:42 PM   #19
With what work?
Old 07-12-09, 08:54 PM   #20
weecorey
With what work?
I take it your asking about the 89BHP bike, high compression pistons, carrillo rods, lightend fly wheel, gass flowed head with race cams, and alot of tweeking I believe.
Car compression test lukemillar Idle Banter 10 14-07-09 10:21 PM
compression kingy916 SV Talk, Tuning & Tweaking 3 30-01-09 02:48 PM
Low compression, possible causes? bikedoc SV Talk, Tuning & Tweaking 8 26-01-07 07:19 PM
high compression pistons and general help needed trick SV Talk, Tuning & Tweaking 8 07-08-05 10:57 PM
Low Engine Compression CamScooby2 SV Talk, Tuning & Tweaking 2 02-06-05 10:52 AM
