#11 |
Ever heard of someone putting ZX6R B1 wheel on back? Is 5.5" and looks similar.
Anyone here got one to take some preliminary measurements?
#12 |
Havent heard of that one. The CBR one fitted so well barring the spacer it looked like it was made for the SV! LOL. Very cheap too off ebay. Just make sure if you get on that its the post 95 model one with the 5 inch rim as the pre 95 wheels look the same but are 4.5 inch on the rim and will flatten the profile of the 180.
#13 |
Biggest advantage IMO is that 120/180 'pairs' seem to be in the sales all the time, hardly ever see any 120/160 pairs for sale. :-/
Doubt it would make much difference to turn in, while it mght slightly, the turn-in speed is more dictated by the geometry[1], what it does do is reduce the speed you can carry a certain speed at. Or to put it another way, if you were to take a corner at 40mph on two identical bikes, one with a 160 rear and one with a 180 rear you'd need to lean more on the bike with a 180 rear. As to the actual amount and if it makes a difference in reality I don't know. Druid [1] The SV is a lardy bus compared to for example an NC35 which has a 10cm shorter wheelbase, even when the NC35 is wearing the same size tyres (std NC35 is 150 rear but a 160 fits).
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#14 |
SV has cruiser geometry as stock. Shorter forks and a 350mm shock soon sort that.
I don't believe you about the lean angle. Surely F = mv^2 / r and the F is a sin of the weight at some angle to the vertical.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 14-12-09 at 06:33 PM. |
#15 |
#16 | |||
See http://books.google.co.uk/books?id=8...20book&f=false Page 2-17 and 2-18, which says Quote:
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 14-12-09 at 09:54 PM. |
#17 |
just dropped mine 5mm at the front at jacked the back up buy 38mm not sure how the 5mm at the front will make a diff but the back made a huge difference
at some point i would like to put a 180 on the rear but not at the moment |
#18 |
Ok so I missed that part entirely
![]() A short wheelbase isn't the be-all and end-all of good handling though. You could probably get some good improvement by getting rid of the 'busa forks and fitting some revalved GSXR6/750 ones. What shock have you got? Is it meant for SV or is it a SRAD one?
#19 | |
I've got some GSXR6 forks to go on[1], The shock is a proper SV Ohlins one.
But that won't appreciably change the speed at which you can turn in[2]. The NC is insanely quick to turn in. While wheelbase is not the be-all and end all it makes a *huge* difference as to how quickly you can turn in. I'm once again going to refer back to the book I referred to before, page 3-16 now; http://books.google.co.uk/books?id=8...20book&f=false Quote:
Druid [1] I just need a GSXR6/750K6-K8 front wheel & discs. [2] Except maybe at high speed, the GSXR6/750 wheel is lighter than the TL and runs smaller lighter brake discs.
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 15-12-09 at 12:13 AM. |
#20 |
But speed of turning is not the be all and end all of handling, everything is a compromise. I bet the SV can put its power down without wheeli-ing more easily for example.
Was that ohlins fresh out of box or has someone revalved it?
