#11 |
Linking the rear caliper into the same braking system as the front calipers is quite feasable. The only difficulty would be in finding the correct size of master cylinder to use and fitting a pressure limiting valve into the rear brake line.
#12 | |
fantabulas
you are not allowed by law only to have one braking system on a motorcycle. There must be a two. Motor bicycles registered on or after 1 January 1927, must have an efficient braking system with two means of operation or two braking systems with separate means of operation. Various locations may be used for braking controls. Some motor bicycles have both braking systems operated from the handlebars and some are linked where both the brakes to the wheels can be operated from either control.
My Flickr photos |
#13 |
My Guzzi was linked braking although IIRC you could apply the back brake on it's own.
#14 | |
fantabulas
yes, so it had two braking systems. MOT standards
My Flickr photos |
#15 | |
#16 |
fantabulas
So it still had two braking systems, I've never said any thing about twin braking systems, The VFR800 in the garage has the same sort of system (see post no#9).
I simply stated a bike with only one braking system for both front and rear is not lawfull.
My Flickr photos |
#17 | |
#18 |
I think some stunt guys use a second lever on the left bar to operate the rear brake - I'm not sure if it's hydraulic or cable-actuated.
I used to have a TZ250-based supermono project. The TZ has a thumb-operated fast-idle control: Looks like the thumb-brake control but it's attached to a cable. I had planned on using it as a poor man's thumb brake by connecting a cable to the rear-brake lever. Not sure if it'd provide the desired power, but might be worth a shot for cheap.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
#19 | |
![]() I'll go away now ![]() |
#20 |
Thanks everyone for the posts.
Don't think I want to be messing around with switching brake lines to just the front lever, as Ophic said, don't think I'd feel comfortable not having control over distribution of braking power. I'd rather just buy a thumb brake assembly. Not bothered about DLVA/Insurance, as said in original post, the SV is my only mode of transport so I'll pay whatever admin fees/premium I need to to get back on the road (Now into 5th month of not being on the bike ![]() Richie - Many thanks for all the useful info. Thanks again. |
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
Brake light switch sticking on with front brake | rick0361 | SV Talk, Tuning & Tweaking | 6 | 11-06-09 06:20 PM |
Brake Bleed nipple/Mityvac/Brake Fluid query | Ceri JC | SV Talk, Tuning & Tweaking | 15 | 20-01-09 02:04 PM |
Neither Brake lever works the brake light anymore | kellie000 | SV Talk, Tuning & Tweaking | 13 | 29-12-06 12:15 PM |
brake light flickers when the front brake pulled in - K4 | dclifford | SV Talk, Tuning & Tweaking | 9 | 05-09-05 10:39 AM |
