Old 19-12-09, 09:27 PM   #11
sunshine
Default Re: Bar end weights: One now weighs less than the other - problem?
both affect it, where the weight it affects as well, keep the weight as central as possible is how you do it
Old 19-12-09, 10:10 PM   #12
barwel1992
ahh yeh now i get you
Old 19-12-09, 10:29 PM   #13
ophic
ophic's Avatar
a few mm makes a noticeable difference? I doubt it. I also seriously doubt bar ends make much difference to handling at all, unless you go to the extremes of hanging a few kilos off the ends of the bars.
Silver SV650SK3, Fuel exhaust
Old 19-12-09, 11:19 PM   #14
sunshine
put the bar ends with the shot weights in them then use mine and you really feel the difference, and everything that helps to throw the bike from side to side i will take.
Old 20-12-09, 02:16 AM   #15
ophic
ophic's Avatar
just take them off then.
Old 20-12-09, 10:41 AM   #16
Bar end weight affects turn in by raising the CoG not by the weight being outboard.
If you want bike to turn in sort out the cruiser geometry of it, on 2gen people seem to settle on a 340mm shock length and GSXR forks which are an inch or so shorter.
On 1gen you can make shock 345mm or longer.
Couple grams on bars I doubt you'd notice.
Old 20-12-09, 11:46 AM   #17
Lozzo
Wow, you must be some kind of a riding god, ever thought of teaching Keith Code some tricks?
I ain't slow myself, and the only noticeable difference I can feel when the bar end weights are removed is the bars have slightly more vibration.
Old 20-12-09, 01:41 PM   #18
sunshine
yep more vibrations and you can feel the weight, i hated not having bar ends when i dropped the bike and changed the bars without having new bar ends
Old 20-12-09, 06:45 PM   #19
Lozzo
No sentient being would ever be able to tell the difference in weight at the ends of the bars in normal, or even track riding. No-one moves the bars far enough or fast enough to be able to detect anything like that, and if you do, then you should seriously consider getting some advanced training before you hurt yourself.
All you'll ever notice is a change in the vibration levels tramsitted up the bars and into your hands
Old 20-12-09, 07:14 PM   #20
They will change the natural frequency a touch, maybe you'll notice if you tankslapper a lot
Bar end Weights metalmonkey SV Talk, Tuning & Tweaking 23 08-11-09 09:30 AM
Bar end weights gavinsky23 Stuff Wanted 9 11-06-09 04:15 PM
Bar end weights Nyarlathotep SV Talk, Tuning & Tweaking 7 25-07-08 04:37 PM
Anyone know what a standard SV really weighs? northwind SV Talk, Tuning & Tweaking 21 31-01-08 10:03 PM
Bar End Weights doe SV Talk, Tuning & Tweaking 6 10-04-06 05:11 PM
