Old 28-12-09, 11:18 AM   #11
5hort5
Default Re: CCT Change Tomorrow
mmm, ok - that makes the assumption I've ever checked my valve clearances (which I haven't), is there a way of doing this without taking tops off engines?
5hort5 is offline   Reply With Quote
Old 28-12-09, 11:23 AM   #12
Yes but it is harder than just taking valve cover off
Old 28-12-09, 11:25 AM   #13
5hort5
this is beginning to sound more than what I can do tbh. Is it worth starting this if I will probably get it wrong?
Old 28-12-09, 11:26 AM   #14
trust me it is not bad to do. Extra part is just for safety, actual job is same.
Old 28-12-09, 11:27 AM   #15
5hort5
ok so, what do I need to do then YC, apart from what I have listed above?
Old 28-12-09, 11:32 AM   #16
Before you attack tensioner;
unbolt horn
move rad forward
take valve cover off
[what you did in post #4]
Then you need to look at cams, they should be pointing away from each other like this \ / it is pretty obvious, you can see the lobes of the cams (pointy parts) .... they should be pointing outwards away from the valves.
If they look different and valve is open then rotate the engine another 360 degrees [like in post #4] (crank is geared 1:2 with cams so this will turn cams 180degs)
Old 28-12-09, 11:33 AM   #17
5hort5
ok, well in for a penny, etc etc
Old 28-12-09, 01:04 PM   #18
5hort5
ok - carbs are off, the o-rings for the choke plungers are knackered though, is there anywhere on the high street that sells generic o-rings? (about 1 cm internal Diameter, 1.2 external)
Old 28-12-09, 01:20 PM   #19
Motor factors, engineering supply. That sort of place
Old 28-12-09, 03:35 PM   #20
5hort5
Right, the CCT is out and it appears to be fine, as it works the same as the others I have, screws in ok and springs out ok???? So shall I just put it back in again?
this is what it looks like down the hole,there's this mark and then a sort of a lip and a mark in the metal below that - look normal to you?
Tomorrow, tomorrow.... yorkie_chris Pennine Massive 4 21-05-09 08:10 PM
Spend £117 & change on bike - but no change in bike pete m Bikes - Talk & Issues 10 06-05-09 12:26 PM
Tomorrow We Will Mostly Be... Lissa Bikes - Talk & Issues 43 22-05-08 09:08 AM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
