Old 21-01-10, 02:24 PM   #11
Dave20046
Dave20046's Avatar
Default Re: Fork bottom bits
Originally Posted by 5hort5 View Post
Depends how much you want for them Dave, I may consider it and do a rebuild on them with and just replace mine but that would be later in the year. If you put in a nice yellow tank at a discount then that would sweeten the deal
I'll get back to you on that one - still waiting on the money to materialise!
Fork lowers? £20
(I can give you them with all the internals, only done 12000 hard miles - may well be better than your current ones)
Old 21-01-10, 05:56 PM   #12
Yer, I'm happy to keep em clean dizzy, it just sounds like a job that's better with the forks off the bike tbh,.
Thats the way I thought you were doing it! Be a PITA if it weren't.
Old 21-01-10, 06:01 PM   #13
5hort5
Apart from not knocking the bike over is taking the forks off relatively simple, I suppose it is so the question should be how easy is it to get wrong when putting them back on?
5hort5 is offline   Reply With Quote
Old 21-01-10, 06:05 PM   #14
Dave20046
Dave20046's Avatar
easy its about 10 bolts.
wheel out calipers off (be wary of the amount of strain you put on the brake lines) mudguard off, loosen all your bolts on the yokes (worth loosening everything before takin wheel off) note how much the forks are protruding above the top yoke and slip the fork legs out.
Old 21-01-10, 06:14 PM   #15
barwel1992
6 actuly lol well if u dont count the wheel bolts/mud guard/brakes, its 14 bolts for the whole lot
tiz very easy to get them out, i wouldent bother removing the yokes thogh
Old 21-01-10, 06:26 PM   #16
Dave20046
Dave20046's Avatar
cause you don't need to
Old 21-01-10, 07:54 PM   #17
5hort5
Yer I figured getting them out was easy but is it as easy getting them back in and aligned correctly as easy?
Old 21-01-10, 08:07 PM   #18
Dave20046
Dave20046's Avatar
Its fine, just take yer time
Old 21-01-10, 08:14 PM   #19
5hort5
Ta m8, this will be my summer project for a damp week, my forks just look in a bad state (along with lots of other bits) so I have new seals, dust covers and springs ready to fit so I may as well do a full strip and clean on em and get the lot right in one go.
Frame Slider Bolts rick0361 SV Talk, Tuning & Tweaking 0 26-03-08 10:26 PM
exhaust slider? passenger-peg mounted. wamanning SV Talk, Tuning & Tweaking 5 09-11-07 03:59 PM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
Fork Finish? Berlin SV Talk, Tuning & Tweaking 30 07-09-07 07:52 AM
SV650 k3-7 : Fork Slider - Mission Impossible ? insideyou SV Talk, Tuning & Tweaking 2 03-09-07 11:45 PM
