Old 30-01-10, 09:08 PM   #11
Supervox
No more Mr Nice Guy
Supervox's Avatar
Default Re: IT Help Req'd - Dual Boot
I have 1Gb RAM - but what is a VM ?
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 30-01-10, 09:24 PM   #12
Sudoxe
A virtual machine, like VMWare, allows your computer to pretend its another one and run two operating systems at the same time.
It's not a great idea for music though, as it will be higher latency for inputs, which can be a pain for direct recording and midi.
Dan
Old 30-01-10, 09:58 PM   #13
-Ralph-
Originally Posted by fastdruid View Post
Seriously I wouldn't bother. I'd run Windows 98 in a VM.
Otherwise you need to wipe XP, repartion, install Win98 and reinstall XP.
Druid
Dan
You have a PM
Old 30-01-10, 10:07 PM   #14
-Ralph-
Could some kind person provide me with an idiots guide to setting up a dual boot system ?
If you do want to go down the dual boot route, setup two partitions, one primary active, and either an extended or another primary, doesn't matter.
Load Windows 98 on the primary, then from Windows 98 stick in your XP CD and run setup from within 98. Reject the prompts to upgrade and tell it you want to do a new installation, selecting the second partition as the target. I'm pretty sure that if you do this from Windows 98, it will edit the boot.ini file for you. If it doesn't, open your boot.ini in notepad from the Windows 98 once XP is installed, and cut and paste it into as post here, we will edit it for you.
Old 31-01-10, 02:47 AM   #15
Sudoxe
You have a PM
No I don't?
Old 31-01-10, 03:06 AM   #16
barwel1992
the way i do it is have 2 hdd's instal windows on one install 98 on the other then load drivers and stuf to both OS's and when the pc starts click F8 (i think) and select what hdd to boot from (learn what HDD is which) worked for with with xp and vista until i decided vista was pants :P
Old 31-01-10, 07:58 AM   #17
Supervox
No more Mr Nice Guy
Supervox's Avatar
Thank you all for your advice.
Old 31-01-10, 12:15 PM   #18
-Ralph-
No I don't?
Neither does Fastdruid
The OP does though, about VM's.
Old 31-01-10, 01:09 PM   #19
steveg
steveg's Avatar
Slap vmware player on it as long as your host pc is meaty enough
Cheers Steveg
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 31-01-10, 01:11 PM   #20
barwel1992
^ i think he will need more than 1gb of ram thogh, when i used it on xp64 bit ages ago i used 6gb lol
IT Help req'd Supervox Idle Banter 8 16-07-09 09:19 AM
Visual Basic help req'd Supervox Idle Banter 6 22-06-07 10:56 AM
HELP !! IT Bod req'd !! Supervox Idle Banter 17 17-04-07 01:31 PM
fork oil 15 or 20? advice req'd. will SV Talk, Tuning & Tweaking 11 20-06-05 07:16 PM
radiator problem? help req'd. will SV Talk, Tuning & Tweaking 4 15-04-05 07:24 PM
