#11 |
I have an alarm like that.
With ignition on, press and hold both buttons together for ten seconds. It will bleep and that disarms the system so you can remove battery, store the bike for winter etc. It is immobilised though, so should still keep scum off your pride and joy. To reset after, switch on ignition and press the larger button as normal when it starts to chime. Good luck. |
#12 |
Datatool alarm? Best solution to those is a big f***ing hammer.
#13 |
+1. mine removed in one hour best mod ive done to the bike.... thatcham secure my ****!!
#14 |
i agree with the 2 posts above.
once you have trouble it always will be trouble and you can bet your life you will be miles from nowhere when it finally gives up. they are not hard to take out. follow all the black wires and theres only a couple that really matter and you will see where the original wires went. most of the black wires are for flasher/l.e.d/ etc etc its the pump, starter and coil ones you need to get right. took me 10 minutes in total to sort one ![]() |
Datatool alarm | nickodemon | SV Talk, Tuning & Tweaking | 20 | 03-01-10 09:44 PM |
Datatool Alarm HELP please | gowiththeflow75 | Bikes - Talk & Issues | 0 | 04-06-09 07:02 AM |
Datatool S4 Alarm | COLZO | Bikes - Talk & Issues | 3 | 13-03-09 12:40 PM |
Datatool Alarm - Problem - Urgent!! | ridelikaking | Bikes - Talk & Issues | 5 | 20-06-06 04:47 PM |
Datatool 3 alarm help ... | sprocket | SV Talk, Tuning & Tweaking | 20 | 29-11-05 05:01 PM |
