Old 27-11-05, 04:14 AM   #1
sprocket
Default Datatool 3 alarm help ...
Ok so the bikes been off the road for a while now and I had to disarm the alarm before I could strip the bike.
The alarm has a sensor at the back of the bike which used to go off when the rear fairing was removed.
The problem now occurs when I'm reconnecting the battery as the alrm is setting off immediatly wven though I've put the sensors in the same place as before.
So does anyone have a suggestion about this or know about this type of alarm?
Thanks in advance.
Old 27-11-05, 09:55 AM   #2
John Burt
It's probably just the alarm sensing the current change when you reconnect hte battery, try disarming it with the key fob. From memory the datatool peimeter switch is not bothered wether made or open the alarm just looks for a change of state. For future reference always put the alarm into service mode before disconnecting battery etc.
Old 27-11-05, 10:39 AM   #3
Skullmonk3y
Old 27-11-05, 01:33 PM   #4
TSM
The Sick Man
TSM's Avatar
If you are having problems turning the alarm off, or when you turn it off it just starts again, check the fuse to the alarm. If this is blown it will not work correctly. Also try dissarming the alarm with the ignition turned on.
Dont go removing any switches or wiring as this may make the insurance company a bit iffy in the event of the bike being stolen and as said before the switch only looks for a state change eg on-off or off-on. I have broken a bit off my switch so its never pressed down when the seat is on, apart from that the alarm still works fine.
Old 27-11-05, 02:08 PM   #5
sprocket
Yeah it was in service mode when I disconnected the batt. BTW I noticed your from plymouth .. have you checked out southwestbikers. Great for hooking up with bikers in the local area.
Old 27-11-05, 02:09 PM   #6
sprocket
Also cheers for the advice guys, im gonna have another crack at it in a mo.
Old 27-11-05, 09:09 PM   #7
admin
John T
admin's Avatar
I concur with the others. I read somewhere that you should put into service mode and remove the alarm fuse, in case you spike the alarm.
I the alarm is spiked then you can use this info to reset it.
http://www.datatool.co.uk/pdfs/system3_ds.pdf
and the owners manual
http://www.datatool.co.uk/pdfs/system3_ug.pdf
also FAQ
http://www.datatool.co.uk/consumer/s...p?prod=system3
admin is online now   Reply With Quote
Old 28-11-05, 08:54 PM   #8
sprocket
does anyone know where the inline fuse is on the PCB I cant seem to see where it is?
Old 28-11-05, 09:42 PM   #9
sprocket
dont worry all sorted, wasn't on the pcb lol
Old 28-11-05, 09:59 PM   #10
TSM
The Sick Man
TSM's Avatar
the inline fuse is the one near your fuse box on a fly lead, the PCB has a battery link (little black thing) that you have to remove.
Datatool S4 Alarm COLZO Bikes - Talk & Issues 3 13-03-09 12:40 PM
what alarm should i get datatool or meta zsv650 SV Talk, Tuning & Tweaking 24 23-09-08 10:52 PM
Datatool Veto Evo Alarm andyharding SV Talk, Tuning & Tweaking 4 08-03-08 10:11 AM
Datatool System 3 Alarm - Help please Matt Prince SV Talk, Tuning & Tweaking 6 04-12-07 03:12 PM
Datatool snitcher alarm adw Bikes - Talk & Issues 1 05-06-07 11:14 AM
