Old 07-04-10, 06:56 PM   #11
bobbleheadbarne
Default Re: Small issue with SV
try small garages they maybe cheaper like i said 150 that was for new shims and top overhaul and carb balance
Old 07-04-10, 06:57 PM   #12
It's less than an hour of a job. However I'd check some other things as well as the balancing.
Old 07-04-10, 06:59 PM   #13
jonny.boyd
jonny.boyd's Avatar
What other things would you suggest be checked YC?
jonny.boyd is offline   Reply With Quote
Old 07-04-10, 07:09 PM   #14
The plugs and check the carbs for water and crap build up. fact it improves when hot means it could be a little lean.
If carbs are badly out the rear tends to run rich and the front run a bit hot.
Old 08-04-10, 11:09 AM   #15
jonny.boyd
jonny.boyd's Avatar
Default Re: Tickover low and erratic.
Hiya there, just called the garage who i bought the bike from (is still under warranty) and surprise surprise they gave me a whole list of things that it could be which meant it wasn't their responsibilty!!
Firstly they said that a restrictor could cause this to happen (only started happening this week, so thats unlikely!)
Then said that it could be dodgey fuel (only topped it up at the weekend)
Gonna fill it up tonight anyway so will see if that does anything.
I was quoted by another garage just under £50 for a carb balance, is it worth doing? Does the restrictor kit affect the balance of the carbs?
Old 08-04-10, 12:07 PM   #16
gettin2dizzy
You would be able to buy a carbtune for under £50. They really keep their value so if you sold it on you could do it for free. It's v. easy.
What about this warranty though? Did you buy a s/h bike from a dealers?
Old 08-04-10, 12:39 PM   #17
jonny.boyd
jonny.boyd's Avatar
yeah was s/h from a yamaha dealer. But their throwing around excuses so doubt they'll actually do the job unless the bike has physically stopped running.
Old 08-04-10, 03:18 PM   #18
gettin2dizzy
It is their responsibility though. The premium you pay for a bike from a dealer is for this service. I''d just get rather vocal about it around potential customers of theirs.
erratic Idle & jerky low speed performance Interceptor SV Talk, Tuning & Tweaking 4 01-06-09 10:26 PM
Erratic idle cat0020 SV Talk, Tuning & Tweaking 11 22-10-08 08:36 PM
Erratic speedo and tacho, engine very hot. chakraist SV Talk, Tuning & Tweaking 2 17-07-08 03:19 PM
Erratic Speedo? cowie SV Talk, Tuning & Tweaking 4 14-06-07 10:12 PM
Faulty/erratic speedo reading SV1000 ginger SV Talk, Tuning & Tweaking 5 03-05-05 10:05 AM
