Old 25-04-10, 02:51 AM   #11
Default Re: 99-02 caliper swaps
Originally Posted by Preston View Post
Yeah i seen the convert plate from TWF, and the spacers but am not a fan, look abit out of place so am doing to get on the CNC and make somthing bit better... ill post some pics when am done.
What convert plate from TWF, they don't make one for back to look out of place.
Old 20-06-10, 07:56 PM   #12
Preston
Default Re: 99-02 rear caliper alternative?
well dont see the need to go though all that ball ake of doing that mod when there are better and easyer things out there. so i put a GSXR 1000 K2 gold caliper on... works alot better.. Dame site better no modding need'ed,
Old 20-06-10, 08:37 PM   #13
rictus01
rictus01's Avatar
without regular servicing any caliper will become less efficient, and with it the standard SV one is more than capable, seems a lot of faff over nothing.
Unless of course you just want a gold one
Cheers Mark.
Old 20-06-10, 08:38 PM   #14
that is same caliper just painted gold
ball ache of duc caliper saves over 1lb from unsprung weight.
Old 20-06-10, 08:41 PM   #15
rictus01
rictus01's Avatar
as I've said many times, if that's the aim, I wouldn't be starting from there.
Cheers Mark.
Old 20-06-10, 08:45 PM   #16
It also has coated pistons, and is anodised throughout, meaning massively reduced corrosion and chance of seizure
Old 20-06-10, 08:51 PM   #17
rictus01
rictus01's Avatar
which is of immense benefit if you don't regularly service it .
Old 20-06-10, 08:57 PM   #18
Makes job easier if you do regularly service it too.
Old 21-06-10, 01:25 PM   #19
Preston
it snot the same AT ALL!!! the pistons are bigger,better seals. Much better way of changing the pads.. More and better pades made for the GSXR 1000 rears than the crap SV calliper.. better anite squile sims.
only ones that are GOld are from the K2 in red black and Silver all others are BLACK!
The braking is better.. having had 2002 Sv650s for 10 years and 2001 track bike for 5 years.. GSXR k2 -k5- and now k9, working and modding bikes befor i could walk.. am not after Silly and pointless comments from people who clearly have no idea what they are talking about..
If you have nothing good to say DONT!...
For anyone who wants a diff caliper that gives better performance this is a VERY good CHEAP! mod thats a simple bolt off and bolt on.. no modding other than to take the old one off put new one on..
Old 21-06-10, 01:35 PM   #20
Typhoon
I know this is going away from what you post was saying but.
Back brake... whats that for.... just a racers view. lol.
Front end, braking wavey discs, performance friction pads, Goodridge Braided Lines, Silkoline Race fluid.... mint.
Back end, Stock caliper, stock pads, stock disc. Its only on so my bike will pass scrutineering.
Just my opinion. But 90% of the bikes braking sould be done by the front. Only good use for a back brake is for very slow manovering, or filtering. Or keeping the front end down at Cadwell.
Alternative rear shock for a curvy? stew SV Talk, Tuning & Tweaking 15 10-04-10 09:10 PM
Alternative Sv rear brake reservoir maviczap SV Talk, Tuning & Tweaking 8 04-01-10 12:41 PM
Rear Caliper... Grinch Stuff Wanted 5 02-07-08 10:06 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
replacement rear brake pedal alternative husky03 SV Talk, Tuning & Tweaking 0 22-05-07 09:43 PM
