Old 30-06-10, 09:59 PM   #11
Weirdfish
Default Re: Chain Adjustment Question
I agree with Chris, make sure you give the wheel a good boot to ensure the adjusters are sitting true, especially if the wheel is on the deck, when adjusting mine I will use a paddock stand and re check the chain tension after I have removed it, I also sit on the bike when I check as your weight will add extra tension to the chain. I would recomend that your chain is a better a tad loose than a tad tight. If it is slightly loose it still wont come off and as long as your are smooth with your gear changes it wont have a diverse effect on transmission, as previously stated. However if it is over tight it could snap, causing much damage to the engine block and possibly your leg. Believe me I know, I learnt the hard way! Lol.
Chain adjustment Tony_BLY SV Talk, Tuning & Tweaking 7 09-05-10 06:17 PM
Which chain adjustment marker (new chain) rockster SV Talk, Tuning & Tweaking 14 22-11-09 02:12 PM
Chain Adjustment plowsie Bikes - Talk & Issues 14 22-04-08 10:26 AM
Chain adjustment?? GC-SV SV Talk, Tuning & Tweaking 4 07-04-06 12:40 PM
Chain adjustment big twin grin SV Talk, Tuning & Tweaking 14 04-07-05 04:20 PM
