#11 |
Aha I understand. Will do if I need to. Thanks.
#12 |
One more thing to remember. Silver solder isn't great for gap filling, so make sure the parts are a good fit as well as clean.
Keith |
#13 |
I'd be very careful soldering to the side tank of any rad, they are made of very very thin alloy and don't need alot of heat to melt a hole
#14 |
If the radiator is aluminium use aluminium solder NOT silver solder. Much lower melting point and less likely to damage the radiator.
If the new cowl has a fixing top and bottom and you are using the end cover fixings that are already on the rad why not just glue a cosmetic fixing to the middle of the cowl[not the rad] so that it looks like it has a centre fixing and then your radiator is still original. Alternatively by a cowl designed for the bike that uses the existing fixings,makes life a lot easier Last edited by Dicky Ticker; 06-07-10 at 06:41 AM. |
Wanted RHS (Throttle side) radiator hose. | weecorey | Stuff Wanted | 3 | 03-05-10 07:16 PM |
Anyone got a left side rear set and side stand? | Dhayn | Stuff Wanted | 6 | 17-08-09 10:08 AM |
Radiator side things | Horney | For Sale - SV's and SV related items | 4 | 25-09-08 07:34 PM |
Left side? Right Side? | lukemillar | Idle Banter | 23 | 16-03-08 08:07 PM |
Get off the RIGHT side not the right HAND side | DavieSV | Bikes - Talk & Issues | 15 | 12-12-06 06:19 PM |
