Old 27-09-10, 04:50 PM   #11
mikerj
Default Re: Which GSXR shock suits K8?
I have a ZZR1400 shock on mine, spring rate seems pretty well matched to my (admittedly ample) frame and no cutting needed (you do need to remove the plastic shield in front of the battery box though). That said I couldn't find any details on the actuial spring rate, but from the number of turns and wire diameter it's somewhat lower than a ZX10R shock.
Old 27-09-10, 08:38 PM   #12
sukirider
cheers for all the advice fellas looks like there are a few options about will delv deeper and post upgrades when done
Old 27-09-10, 08:39 PM   #13
How much you weigh?
Old 06-02-11, 10:14 PM   #14
badsaboy
sukiridr did you get a rear shock? which one did you get and how much do you weigh if you dont mind me asking?
Old 06-02-11, 10:46 PM   #15
g13unisol
Just fitted a k5 gsxr1000 rear shock to my sk9 all I need was a gsxr1000 bottom shock bolt and nut cost £6 from George whites and some thread lock reused old nuts only a little cutting needed of the battery tray. I got a new smaller battery £32 so does not touch seat. You can use cut out plastic to remake tray to stop battery hitting shock.
Old 07-02-11, 07:07 AM   #16
badsaboy
do we know of any shocks bar the expensive ohlins etc which do not require the battery box to be cut?
Old 07-02-11, 11:22 AM   #17
mikerj
On a pointy the ZZR14 and 06-07 ZX10R shocks simply need a small plastic part unscrewed from the toolbox/battery box to fit. Completely reversible if for some odd reason you wanted to fit the original etc. ZZR shock will probably have too high a spring rate unless you have a pie retention problem
Sadly you don't find many ZX10R shocks (of the right year) going cheap on eBay etc.
Old 07-02-11, 01:00 PM   #18
Gordon72
i got a 07 zx10 shock as i was fed up with the suspension on the sv.
Came with the rest of the bike still attached!!
Old 07-02-11, 01:04 PM   #19
badsaboy
Cheers Mike
I proberly weigh 200-210 with kit. would the zx10r suit my weight?
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
K4 GSXR 600 Shock into a K1? mattyL Bikes - Talk & Issues 5 18-05-07 05:48 PM
GSXR shock on a K3 lukemillar SV Talk, Tuning & Tweaking 9 05-04-06 09:30 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
GSXR Shock The Wolf SV Talk, Tuning & Tweaking 12 23-03-05 12:04 PM
