Old 29-11-10, 08:34 PM   #11
hongman
Default Re: Filing down a lever?
B&Q tomorrow then...
Thanks
Old 29-11-10, 09:44 PM   #12
barwel1992
ps id still lap it
Old 29-11-10, 09:51 PM   #13
Clutch levers will always go too hard to pull if you overtighten bolt. Experiment with your stock one to find right tension.
Old 29-11-10, 10:30 PM   #14
beabert
Try longer bolt and two nuts?
Old 30-11-10, 01:04 AM   #15
hongman
On the current thickness, in order for the clutch lever to return properly the nut has to be dangerously loose...like, I think it'll vibrate off very very quickly loose.
Unless I screw it hand tight and thread lock it?
Old 30-11-10, 01:05 AM   #16
barwel1992
or get a longer bolt
Old 30-11-10, 01:06 AM   #17
hongman
The one I have is pretty though with unique markings.
Old 30-11-10, 12:24 PM   #18
Stonesie
Nylock nut?
You should be able to find some in B&Q or a motor factors.
Old 30-11-10, 01:31 PM   #19
hongman
Yeah, I'll have a gander when I get a moment to.
Thanks
Old 30-11-10, 01:33 PM   #20
barwel1992
make sure you get the blue nyloc nuts as they are metric and not the white imperial ones or they wont fit properly
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted Drumming_Animal Stuff Wanted 0 26-07-10 10:52 PM
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
Gear lever as rear brake lever? plowsie SV Talk, Tuning & Tweaking 2 29-05-07 05:23 PM
