Old 06-01-11, 08:14 PM   #11
DavieSV
DavieSV's Avatar
Default Re: How to measure spring rate?
Originally Posted by zadar View Post
RSVR as aprilia 1000? those are usually in 500lb range for race bike with lighter rider.
If you using 1.0 in front you should be around 550 on rear.
Yes standard sachs shock from Aprilia RSVR 1000 K6.
DavieSV is offline   Reply With Quote
Old 06-01-11, 08:33 PM   #12
zadar
Not sure what rate standard Sachs uses, I know guys run 500-600 on those bikes.
Old 06-01-11, 11:22 PM   #13
But this shock is on SV.
If you are getting lots of squat with lighter spring, what length is shock set at? If short that can mean lots of squat as you open it up and running wide.
To calculate spring rate is very simple, units are pounds per inch... force per displacement so just divide force by displacement.
Springs are often non linear at the extreme ends of their compression so you should log a curve every couple of mm, there may be some odd bit in first 5mm that can be ignored. If you plot a curve then just measure gradient of the line.
Old 07-01-11, 10:37 AM   #14
DavieSV
DavieSV's Avatar
Shock is set slightly longer than stock.
Old 07-01-11, 10:59 AM   #15
Try +10mm from stock, 340mm between centers.
sv1000 spring rate? bigchris SV Talk, Tuning & Tweaking 1 28-05-10 09:42 PM
spring rate calculation widget SV Talk, Tuning & Tweaking 2 23-11-09 03:43 PM
Spring Rate and Oil Weight? PURPLE SV Talk, Tuning & Tweaking 4 25-05-09 07:43 PM
Fork spring replacement... Forgot to measure travel beforehand. Troy SV Talk, Tuning & Tweaking 10 28-07-08 09:53 PM
Which spring rate for a chunky rider? Biker_Billy SV Talk, Tuning & Tweaking 11 04-02-08 12:27 PM
