Old 12-01-11, 04:54 PM   #11
husky03
Default Re: How much do you use the rear brake?
on your police motorcyclist course your instructed that any braking from 20 and under is to be done by using the rear brake(unless emergency stop then both front and rear) so since then thats what I do
Old 12-01-11, 04:56 PM   #12
sv4me
sv4me's Avatar
Originally Posted by Berlin View Post
0%, nada, nowt, never
i've seen so many people actually cause lock ups by being rear brake happy.You could quite happily take mine off and I wouldnt notice
Stu I have a worse example of when to use the rear brake, a guy I knew who fancied himself as a bit of trackday demon said use the back brake to control the rear when backing it in
Old 12-01-11, 04:56 PM   #13
TamSV
TamSV's Avatar
I use the rear alot when carrying a pillion. Not so much otherwise.
Old 12-01-11, 04:59 PM   #14
Originally Posted by Stu View Post
IMO - not a good example to use it.
I use mine a lot
??? I didn't mean on it's on own stu, I meant with the front brakes as well, exactly like I was taught.
Old 12-01-11, 05:11 PM   #15
Stonesie
I use it quite a bit at lower speeds and drag it for slow control. When I first started riding the SV I used the rear brake with the front all the time, on my CG125 the rear brake was more powerful than the front...
Old 12-01-11, 05:18 PM   #16
SoulKiss
SoulKiss's Avatar
Use mine all the time - noticed how much when I switched back to the SV from the Zed (Zed had ABS).
No mishaps, but a couple of locks, but its all good
Old 12-01-11, 05:29 PM   #17
TSM
The Sick Man
TSM's Avatar
more of guidence rather than it should be
also surprising how many peeps say they never use it are surprised when the brake is removed that they did not notice using it in the first place
Old 12-01-11, 05:32 PM   #18
DaveW_42
DaveW_42's Avatar
Very very rarely. Maybe when stopping at lights or something but during normal road or track riding I don't go anywhere near it. On the track, the only reason it's there is for the scrutineers!
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings.
DaveW_42 is offline   Reply With Quote
Old 12-01-11, 05:45 PM   #19
mcgrimes
Always use it really, as had been said, its much smoother. Most of my braking is done by the engine!
Engine braking does sound much better.
Old 12-01-11, 05:45 PM   #20
always use both unless i'm slow manoeuvring then i sometimes only drag the back.
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
Brake light not coming on with rear brake. XmisterIS SV Talk, Tuning & Tweaking 5 11-12-09 12:06 AM
footpeg bracket, rear rear brake lever, clip on. plowsie Stuff Wanted 3 05-08-09 03:44 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
