Old 02-02-11, 08:23 PM   #11
husky03
Default Re: Problems dimantling rear caliper.
+1 to the above plus I learnt that welding in slippers isn't a good idea
made me laugh-though i was being sensible with the walking boots on but did i tie them?-no-had the blister scab on the top of my foot for months dam sore.
Old 02-02-11, 10:02 PM   #12
Hehehe. Same thing with rigger boots and a chunk of slag from oxy cutting torch.
Really quick way to learn to dance.
Old 02-02-11, 11:36 PM   #13
monkey
Default Re: Be aware of ham fisted bodgers!
Heh, see if you'd had a look on here first you could have soaked it in plusgas for a while and avoided all this fuss
Is this plusgas stuff better than any other penetrating fluid? If so is there any difference (in effectiveness) between the aerosol version or other?
Old 02-02-11, 11:48 PM   #14
I used to really like the duck oil (iirc) that came in a non aerosol can, but they all seem a bit sh*t these days TBH.
Apparently mixing ATF with acetone can give the similar results to the old school stuff before all this "health" stuff was invented.
Old 03-02-11, 12:07 AM   #15
monkey
Is that a yes? My only experience with such stuff is with 3 in 1 penetrating aerosol.
Old 03-02-11, 12:08 AM   #16
3 in 1 aerosol is fine, 3 in 1 in a can is also good stuff.
If in doubt use both, can't hurt.
It's kinda hard to say what's "best" though, 'cos if it works, who is to say that it was an ACE penetrating oil, or that the bolt wasn't tight...
So buy one you like the smell of
Old 03-02-11, 12:16 AM   #17
barwel1992
i have the 3 in 1 aerosol and its worked so far (apart from the exhaust stud ...)
Old 03-02-11, 12:26 AM   #18
monkey
Fair enough. It does smell really nice.
Old 03-02-11, 07:06 AM   #19
camperman69uk
So it sounds like I shouldn't of bothered with that half a tin WD40 I used to try and the blighter apart
Old 03-02-11, 10:26 AM   #20
WD40 = water dispersant.
Better than nowt but it isn't penetrating oil
Rear caliper gfewster Stuff Wanted 1 19-03-10 07:37 PM
Brake caliper problems - what to do? benjyman Bikes - Talk & Issues 5 12-03-09 06:18 PM
Rear Caliper... Grinch Stuff Wanted 5 02-07-08 10:06 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
rear caliper dirtydog SV Talk, Tuning & Tweaking 24 28-04-08 01:39 PM
