Old 21-02-11, 05:09 PM   #11
tim8061
Default Re: Hagon progressive fork springs?
I added a gel pad from ebay. There's an article at http://www.hforcier.com/sre/gelseat.htm showing a DIY insert, although the one I got didn't need cutting down.
There's also a thread at
http://www.sv-portal.com/forums/showthread.php?t=38958
on DIY seat mods with a downloadable guide with good pictures. So long as you have a staple gun it's quite easy - I reshaped mine first but it was still uncomfy, so I stripped it again and added the pad.
Old 22-02-11, 11:19 AM   #12
mister c
mister c's Avatar
Have had Hagon progressives in mine for years now & as everybody else has said they make a big difference over the sponges that are standard. They stiffen the front up no end.
Old 24-02-11, 08:18 PM   #13
curvy custard
HI, right i just took mine out for the first time since fitting hagon springs(from wemoto may i add) and 15w fork oil, along with a zx636r rear shock. massive improvement over the 12 year old stock set up, dips in the road that i used to hold on for dear life, are gone. fully reccomend unless u can afford a complete front end swap, im planning on that next year.
kev
Old 04-03-11, 08:43 PM   #14
Jordy
I've just bought these from wemoto, went for these over linear because theyre slightly cheaper and I'm not really a fast rider/no track days. Just looking to improve on the dangerously crud standard ones.
I'm taking it to a garage for them to install them, is it worth replacing the oil/dust seals whilst they're apart or only if they're leaking/damaged? Anyone know what I should be expecting to pay for this job?
Old 04-03-11, 10:23 PM   #15
No only if they are leaking. You don't need to remove seals to do this job.
Old 04-03-11, 11:02 PM   #16
Jordy
Ah right, thanks mate.
Old 05-03-11, 06:28 AM   #17
Nobbylad
Nobbylad's Avatar
kev
If you take your time over buying the bits, you can do it for cheaper than buying new springs...I even turned a profit when I did mine.
Old 05-03-11, 09:29 AM   #18
Yeah I would have done too if the first set of discs I bought weren't like poppadoms!
Hagon Progressive fork springs for pointy etuna For Sale - SV's and SV related items 4 18-08-09 04:07 PM
Installing Hagon Progressive Fork Springs Dave20046 SV Talk, Tuning & Tweaking 3 04-08-09 05:58 PM
Hagon Progressive Fork Springs mister c SV Talk, Tuning & Tweaking 12 13-05-08 08:18 AM
Hagon Progressive Fork Springs For Sale ozwaldo For Sale - SV's and SV related items 9 11-05-08 07:44 AM
Hagon Progressive Fork Springs Mike2165 SV Talk, Tuning & Tweaking 17 09-01-08 02:49 PM
