Old 27-02-11, 11:15 PM   #11
Default Re: Fitting carbs to a fuel injected engine
Originally Posted by steviejam73 View Post
So it is doable?
Not an sv engine but I have a classic rover mini that was fuel injected and was converted to a single carb. Guy that did the work just left the injection looms taped up.
What sort of ignition changes would you be talking. If I went for a newer type loom would that sort it.
Thanks
Can you be a bit specific? Is this an SV injection engine you want to run in a carb bike?
If it is like that then it is easy, swap the rotor, stator, carb boots and carbs and it will run same as the carb engine did. Same loom as you're supplying the ignition box with the same inputs as you did before.
Engine just died while riding (after fuel hose fitting) kd80 Bikes - Talk & Issues 3 18-04-10 01:12 PM
sv 650 k3 salvage fuel injected cheap aarmotorsport For Sale - SV's and SV related items 2 10-03-09 05:29 PM
Carb vs Fuel injected florida650 SV Talk, Tuning & Tweaking 18 20-07-07 05:21 PM
CARBED vs FUEL INJECTED KayDee SV Talk, Tuning & Tweaking 22 05-09-05 09:50 PM
Fuel Injected Problems - How Can You Tell? Mike1234 SV Talk, Tuning & Tweaking 0 20-03-05 09:29 PM
