Old 27-02-11, 07:06 PM   #1
steviejam73
Question Fitting carbs to a fuel injected engine.
I bought an '01 sv race bike a few weeks ago with Keihin fcr 41mm race carbs fitted. The bike seized on me so I'm now after a new engine. Does anyone know if a set of carbs can be fitted to a fuel injected sv engine? Would they be able to fit straight on to inlet manifolds or would some manufacturing be required?
Thanks
Old 27-02-11, 07:32 PM   #2
Default Re: Fitting carbs to a fuel injected engine
Nah mate those FCR will only ever fit the original engine, you should sell them to me for a tenner
You might need to swap the rubbers from carb engine. Also need to change ignition system.
Old 27-02-11, 07:58 PM   #3
steviejam73
So it is doable?
Not an sv engine but I have a classic rover mini that was fuel injected and was converted to a single carb. Guy that did the work just left the injection looms taped up.
What sort of ignition changes would you be talking. If I went for a newer type loom would that sort it.
Thanks
Old 27-02-11, 08:05 PM   #4
Electro
If you can get a manifold to accept them and yo can supply enough fuel to them you should be ok. I`ve installed fuel injection to a VW Beetle and stuck 2 twin 40 webers on my beetle, had to fit a fuel pump for supply to the carbs, messes up fuel economy that though.
Old 27-02-11, 08:47 PM   #5
curvy custard
Default Re: Fitting carbs to a fuel injected engine.
Plenty of people covert mk1 and mk2 golf gti's to run on carbs so can't see why u can't do it an sv.
Old 27-02-11, 09:45 PM   #6
minitwin49
I am running carbs on a K4 engine so in answer to your question yes you can. I am running 144 jets if that helps you too
Just plug it in and run everything else from the curvy.
Old 27-02-11, 09:50 PM   #7
Electro
Remember they are going on a car mate.
Old 27-02-11, 09:54 PM   #8
barwel1992
ehh ?
Old 27-02-11, 10:06 PM   #9
squirrel_hunter
squirrel_hunter's Avatar
This I want.
If you decide to go for FI and have no need for these let me know...
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 27-02-11, 10:08 PM   #10
Electro
Off a car oops
Engine just died while riding (after fuel hose fitting) kd80 Bikes - Talk & Issues 3 18-04-10 01:12 PM
sv 650 k3 salvage fuel injected cheap aarmotorsport For Sale - SV's and SV related items 2 10-03-09 05:29 PM
Carb vs Fuel injected florida650 SV Talk, Tuning & Tweaking 18 20-07-07 05:21 PM
CARBED vs FUEL INJECTED KayDee SV Talk, Tuning & Tweaking 22 05-09-05 09:50 PM
Fuel Injected Problems - How Can You Tell? Mike1234 SV Talk, Tuning & Tweaking 0 20-03-05 09:29 PM
