Old 01-06-10, 06:21 PM   #1
squirrel_hunter
squirrel_hunter's Avatar
Default SH2: The Rebuild (Image Heavy)
Well last year I ran the engine out of oil again. Between then and now I learned to drive a car and stole Stretchie's Blackbird. But I need my SV back and at the moment I have plenty of time on my hands. So here is a rebuild thread to document my slow progress and hopefully prevent me from loosing another £50 bet.
Part 1; Dismantling:
Yes that is an oil drain try beneath the bike, oh the irony.
Prop the tank up to get to the air box.
Then remove it.
Drain the coolant.
Disconnect the carbs.
And remove them.
Take the clutch drive, the gear leaver, and the chain off (Its easier to remove the rear wheel or slacken it off to get the chain over the sprocket).
Remove the radiator.
Take the exhaust off, the rear cylinder collar was rusted nicely.
Disconnect the electrics.
Then drop the engine out.
Leaving a lonely engine on the floor.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 01-06-10, 06:24 PM   #2
mattSV
mattSV's Avatar
Default Re: SH2: The Rebuild (Image Heavy)
Your downpipe needs a polish
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 01-06-10, 06:41 PM   #3
squirrel_hunter
Part 2; Getting Into The Engine:
With the engine on the workbench, we can begin.
Starting at the front and then replicating at the rear, take the valve covers off.
Exposing the camshaft holders.
Removing them to get to the cams.
Cams out, the valve head comes off.
As does the cylinder.
So we can see the piston.
Remove the piston noting the wear to the pin.
Take the clutch out.
And find its in pieces.
Take the oil pump off and the generator from the other side and the associated gears from the crank.
Leaving the cases ready to be split.
Separate the cases showing the gear box.
And the crank.
Old 01-06-10, 06:44 PM   #4
squirrel_hunter
Fancy giving it a go?
It will most likely go back on looking very similar...
Old 01-06-10, 06:56 PM   #5
squirrel_hunter
Part 3; Cleaning Up The Mess:
I didn't find that much metal floating around the engine cases. Which did make me wonder. So I cleaned the little that was there up. That is until I removed the oil filter that is at the bottom of the case in the picture below.
This is where most of my crank ended up as can be seen below.
I've had to do the cleaning up a few times as the engine as sent a bit of time traveling up and down the M4 over the past few months. But it is sitting covered up in the garage at the moment awaiting reassembly.
Old 01-06-10, 07:12 PM   #6
Bluepete
Bluepete's Avatar
Jeez! Glad you know what you're doing. That's so far beyond what I could do. Good on yer!
Pete
Old 01-06-10, 07:15 PM   #7
_Stretchie_
Large Member
_Stretchie_'s Avatar
He was meant to be bleeding the brakes
How to amuze an idiot:
Look right-> <-Look Left
Old 01-06-10, 07:24 PM   #8
squirrel_hunter
Part 4; Piston Broke? Yeah Thats Me:
Well the crank and the barrels went to Piston Broke Engineering, Bristol (0117) 9412300 for a regrind and a bore. The crank came back with bearings from a Ford Scimitar and a pair of cylinders ready to take the new pistons.
Trouble is this is where I lost motivation for a couple of months. Upon regaining the desire to get SH2 back up and running I found that I had mislaid the crank shaft thrust washer. So off to Piston Broke went the engine to get measured for a new one. This took some time.
But once the washer arrived, my gopher was dispatched to retrieve the engine. He did and then dropped it. Back it went to have a new main bearing as the cam chain gear on the crank had left a couple of nice dents it.
This time when the gopher picked it up he didn't drop it and brought it back to me with an extra bit. If anyone can identify what it is I'd appreciate it as I'm fairly confident its not from my engine so will take it back to Piston Broke once I know for sure.
Old 01-06-10, 07:57 PM   #9
Better than reading a Haynes manual, in colour too
Old 01-06-10, 10:56 PM   #10
That actually looks like a fitting for braided brake hose, you got a pic in focus?
Oban and beyond (Image heavy) DarrenSV650S Photos 3 12-06-09 08:53 PM
my new baby *image heavy* Amplimator Photos 17 11-05-09 10:19 PM
Been out for my best ride yet (image heavy) Magnum Photos 26 11-04-09 12:08 PM
Colchester Zoo. Very image heavy! Jester666 Photos 5 11-08-08 07:48 AM
70s bike day at the Ace (Image heavy) empty Photos 6 23-07-07 03:33 PM
Powered by vBulletin® - Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
