Old 03-03-11, 12:19 PM   #11
SoulKiss
SoulKiss's Avatar
Default Re: Do i have a problem?
Originally Posted by Owenski View Post
On that logic indies on mirrors are illegal (over 1200mm high).
Also mine must be illegal as I've 4 front indicators, 2 on the mirrors and 2 side repeaters.
As for the OP, EDIT: just seen the side view pic you posted. You'd be better off measureing it first cos yes, its going to be bloody close.
Standard or flushed into the fairing.
If flushed into the fairing, then there is no limit side facing repeaters
Old 03-03-11, 12:46 PM   #12
Most of which are illegal due to the requirement for a certain minimum spacing of indicators...
Had mine fitted for 3 years and haven't been locked up yet
Old 03-03-11, 01:01 PM   #13
SoulKiss
SoulKiss's Avatar
Just dont go to Wales...
Old 03-03-11, 01:29 PM   #14
-Ralph-
Yep they are - as well as usually useless to the person behind you.
Most of them are not very bright and the colouration in certain light conditions can make the brake light and indicator look very similar.
From the VOSA pdf
Front indicator
Amber
2 max
Min height 350mm
Max height 1200mm
Min distance apart 240mm
Rear indicator
Amber
2 or 4 max
Height as front
Min distance apart 180mm
Max 300mm from rear
Just a bit of clarification here. They need to flash amber, not be amber, correct? Many vehicles come with clear lenses and amber bulbs nowadays.
Old 03-03-11, 01:30 PM   #15
Owenski
Yeah they're flush mounted, Initailly I just got them in prefernce to blanking plates but on fitting the mirror indys I noticed its actually quite hard to see them from the side so having side flush mounted ones as well has worked out as a massive benifit.
Old 03-03-11, 01:52 PM   #16
SoulKiss
SoulKiss's Avatar
I believe the ruling is in respect to the light emitted/seen rather than the lenses/bulbs thing
Old 03-03-11, 06:39 PM   #17
Shaun.
Ah i see, looks like im gonna have to change the exhaust then!
Any ideas how much the exhaust is worth? Its immaculate.
Thanks
Old 03-03-11, 07:17 PM   #18
-Ralph-
You could just change the link pipe so that the exhaust is not high level.
Old 03-03-11, 07:32 PM   #19
barwel1992
and then give me the link pipe and hanger bar
Old 03-03-11, 07:34 PM   #20
-Ralph-
Or just swap your link pipe with barwels ^^^^^^^^^^^^
Problem With Custom Tail Tidy andyharding SV Talk, Tuning & Tweaking 40 05-03-10 12:36 PM
Fitting an Evotech Tail Tidy (normal indicators) disco SV Talk, Tuning & Tweaking 9 05-01-10 11:16 PM
high pipe and tail tidy, potential probs??? eano2 SV Talk, Tuning & Tweaking 3 14-08-07 01:20 AM
Exhaust, High level or not to high level..? Horney SV Talk, Tuning & Tweaking 5 06-10-06 03:54 PM
Tail tidies and high level exhaust diamond Bikes - Talk & Issues 5 25-06-05 06:44 PM
