Old 06-03-11, 08:18 AM   #11
-Ralph-
Default Re: How accurate is the SV speedo?
You can measure the diameter of your wheel and tyre, you know how many mm of tread you had new, you know how many mm of tread are left. You can easily calculate a circumference from a diameter, and convert that into a distance travelled and figure out a number of rotations for a given distance. do it for a knackered tyre and a new tyre and you can easily calculate the difference in speed reading. Personally I can't be arsed.
My vehicles
Pointy SV + 10%
Yamaha XT600 -3% (yes it under reads!)
Seat Ibiza + 10%
Vauxhal Vectra + 5%
Old 06-03-11, 08:29 AM   #12
kaivalagi
Me neither that's why I was hoping someone had a idea of the variation....life's too short though
Mark
Triumph and Suzuki owner
Old 06-03-11, 08:32 AM   #13
I know for a fact ALL VDO manufactured clocks are factory made with an over read of 5%.
My pointy also over read exactly the same as others have mentioned.
Old 06-03-11, 10:35 PM   #14
musne
So the question is:
What is the best device to get to enable you to have the most/more accurate reading of what speed you're travelling at?
GPS?
Old 06-03-11, 11:02 PM   #15
kaivalagi
GPS helps you understand but you don't need it after a while anyway
You could go out and buy a Speedohealer? or whatever the equivalent are...
Manufacturer's site here: http://www.healtech-electronics.com/
Or just get used to it and know that 77=70, 66=60, 55=50
Borrow a gps for a ride to check what your bike comes out then you're done
Mark
Old 07-03-11, 05:20 AM   #16
sath182
If you go the route of a speedohealer, keep in mind that the Odometer used the speed sensor as well so your millage will end up 9% short of actual.
Old 07-03-11, 07:50 AM   #17
kaivalagi
Mmmmmm, here's a question...Is the odometer accurate or does it also have 9% more than actually ridden as standard?
Mark
Old 07-03-11, 08:22 AM   #18
-Ralph-
9% more.
I think musne was asking if GPS is accurate, the answer is, for the purposes of measuring vehicle speed to within 1-2 mph, yes it is.
Old 08-03-11, 12:42 AM   #19
sath182
From what I understand, the Odo is mostly accurate. Just the speedo has the over-read. I did a search on google for "speedohealer odometer" and the first few links have statements that follow this line of thought, but I can't find anything hard from Healtech. I was looking into one of these a while back but remember reading that it would make the Odo wrong so I let it go. I like not running out of gas :P
Old 08-03-11, 07:53 AM   #20
kaivalagi
Good to know, the newer dashs are digital rather than the old fashioned wind up things so it would make sense they are accurate in distance and inflated in speed
Personally I think just knowing the differences in actual speed versus what the dash is telling you is enough anyway
Mark
How accurate should you be when adjusting the chain? cringer SV Talk, Tuning & Tweaking 5 15-06-10 03:25 PM
Is GPS MPH accurate hindle8907 Bikes - Talk & Issues 60 12-08-09 08:16 AM
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. lloyd_christmas SV Talk, Tuning & Tweaking 14 12-06-08 12:02 PM
Google Maps. How accurate? petevtwin650 Idle Banter 1 17-03-08 12:45 PM
Most consistently accurate weather site.... rob13 Idle Banter 16 20-08-07 12:20 PM
