Old 11-03-11, 03:10 PM   #11
toxic
Default Re: How to change my gear lever?
No, I was pointing out to our American friend that they're not called snap rings here.
Old 15-04-11, 05:49 PM   #12
Daveog
Daveog's Avatar
Anyone know where to get aftermarket replacements? Suzuki want £51 and I need a new one before I buy new boots!
2002 SV650S K2 + 2005 CBR125-R (my 2009 SV650S Dark Grey K9 was stolen in Hextable 18/7/12 )
Daveog is offline   Reply With Quote
Old 15-04-11, 06:26 PM   #13
Drumming_Animal
Check out eBay, theres a few curvy ones on there, or there was when i last looked a few weeks ago. Seemed to be all they had.
For pointys, look out for hayabusa ones, theyre the same, ive got one on mine.
Old 15-04-11, 07:09 PM   #14
muzikill
muzikill's Avatar
If you need a replacement circlip check what size you need and give me a shout. I bought a box of different sized ones.
Old 15-04-11, 07:25 PM   #15
musne
Yea eBay is good. I got a used original Suzuki one for around £13!.
Old 15-04-11, 08:38 PM   #16
HoL
Originally Posted by mikerj View Post
Note that the aftermarket gear levers tend to have a folding alloy peg, which is good in that it will fold instead of snap if dropped, but from some peoples experience they tend to scuff up your boots compared to the standard rubber covered peg.
I'm sure you can get little neoprene sleeves that go over the top, wouldn't that save your boot?
Old 16-04-11, 10:29 AM   #17
Daveog
Daveog's Avatar
Cheers Muzikill, will do. Have you got a large version of your avatar picture elsewhere on the forum?
I also wondered this?
Old 16-04-11, 10:34 AM   #18
musne
yup you can get the rubber separately, check on ebay!
Old 16-04-11, 12:18 PM   #19
muzikill
muzikill's Avatar
Ive got it somewhere ....... it is a pretty good photo!
Will this do in the meantime?
Glencoe .... the roads like a runway when you go towards it
Old 16-04-11, 06:21 PM   #20
Daveog
Daveog's Avatar
Very good - looks like an excellent place for riding!
Bought some new boots today so now need to get that gear lever replaced as soon as possible!
Gear change lever for k6 MisterTommyH Stuff Wanted 1 10-10-10 09:16 AM
Gear Change Lever xXBADGERXx SV Talk, Tuning & Tweaking 2 07-11-09 11:25 PM
Gear Change Lever K4 onwards madness Stuff Wanted 0 06-09-09 05:54 PM
gear change lever? arcdef SV Talk, Tuning & Tweaking 21 04-12-08 06:52 PM
Gear change lever Ward8124 Bikes - Talk & Issues 0 03-02-07 04:19 PM
