Old 17-03-11, 02:09 PM   #11
novocaine
Default Re: Help I'm broken down!
reg recs fried.
you got breakdown cover? your going to need it i'm afraid. unless you want to push your bike home that is.
Old 17-03-11, 02:41 PM   #12
YellowMonkeyBoy
I've got her home. I've had her less than 300 miles and already seen under every panel. I like that but no it was a short in the wiring it'd rubbed through on the main seats bar that it loops under. It's quite sharp now I'm home going to check the wiring file that end smoother and such. Thanks for your help oh mighty org
Old 17-03-11, 02:43 PM   #13
YellowMonkeyBoy
Reg,rec was checked when I picked up the new battery so I knew the chances of it being that after riding for a mile or two were slim. 99% sure that this clear break in the loom was the issue just rode all the way home as if nothing was the matter.
Old 17-03-11, 02:44 PM   #14
timwilky
timwilky's Avatar
Common fault is chaffing of the loom near the seat screws
Not Grumpy, opinionated.
Old 17-03-11, 03:09 PM   #15
_Stretchie_
Large Member
_Stretchie_'s Avatar
try and bump start it ignition on, in gear clutch in push as fast as you can while on the bike (find a hill) drop clutch and see if it starts
Just a note for future reference, it's probably best to try a bump start in second gear, for no other reason than if it fires to life and you give it a fistful of beans you are less likely to end up pulling a poo fuelled wheelie
How to amuze an idiot:
Look right-> <-Look Left
Old 17-03-11, 03:15 PM   #16
Geodude
Geodude's Avatar
Loom damaged or rubbing on seat mounting bolts and wires touching together or any other wires?
Glad you got it sorted and my suggestion was of use.
Old 17-03-11, 04:35 PM   #17
Dave20046
Dave20046's Avatar
I think this was staged by Sidsquid !
Old 17-03-11, 04:43 PM   #18
YellowMonkeyBoy
I wish it was staged. I was broken down an the weather started to turn. On the ride back very light showers and now the sky is properly grey but I've gone over it and Filed the pointly bit of metal it was rubbing on down then cushioned it and cable tied it all back up and now issues. New Battery Acid being done ready for the new battery which means I can put the little black panels back on. I reckon because I've had them off so its just 2 screws to get the seat off and jump her ... I hink I might've aided the bike using my left leg leaning on the loom, just a matter of time though I guess on that one.
Old 17-03-11, 04:49 PM   #19
Berlin
To answer a recent question *That* is what a forum is for!!
Old 17-03-11, 06:26 PM   #20
barwel1992
now that sounds like fun!
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
my car has broken down...again! josefine666 Idle Banter 17 28-11-07 11:28 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
It's broken!!! :( alex.j SV Talk, Tuning & Tweaking 7 30-08-06 08:50 PM
I've broken my sv. H-Gerickemark Bikes - Talk & Issues 23 05-06-05 03:01 PM
