Old 25-03-11, 07:46 PM   #11
radicalry00
Default Re: Really slow oil leak from clutch cover
Rightt, cheers husky. You seem to be helping me out a hell of a lot lately
I'll wait until after the weekend to take the cover off and check it. Will order an o-ring anyway but hopefully I won't need to buy a cover as well.
Old 25-03-11, 07:49 PM   #12
radicalry00
Originally Posted by stew View Post
im in the same boat.
stood the bike on the paddock stand over the weekend and had a small puddel of oil on the floor.
going to have a look at re-sealing it next weekend when i do a service.
if it is bent ill leave it till ive got the cash for a new one. just keep an eye on oil level and not leave it on paddock without a small pot under it.
Aye mate, more of an annoyance than anything as it doesn't seem to affect the oil level much. Over 2 weeks it doesn't seem to have dropped hardly anyway. I just want to get mine sealed so I'm not constantly paranoid about it getting worse and checking it all the time.
Old 25-03-11, 07:58 PM   #13
husky03
Brotherhood of Iron mate
Old 29-03-11, 09:29 PM   #14
Dipper
Dipper's Avatar
Had the same problem with mine, took the cover off cleaned up the mating surfaces well and put it all back together used thread lock on the screws and tourqued to spec. (suprisingly low) no leaks now for 3 weeks.
Dipper is offline   Reply With Quote
Old 29-03-11, 09:32 PM   #15
radicalry00
Good to hear. What torque should the bolts be? About 15nm?
Old 29-03-11, 09:50 PM   #16
15 is too much. I think book says 10, but lower is better. Only enough they don't fall out, don't go mental.
Old 30-03-11, 08:57 AM   #17
Dipper
Dipper's Avatar
The book says 10 and they'll fall out if you don't use threadlock, mine is Red and Curvy too, worked a treat, not sure if it'll work on the yellow and blue ones
You can download a copy of the manual fro the FAQ's section of the main site.
Old 30-03-11, 10:55 AM   #18
radicalry00
Default Re: Really slow oil leak from clutch cover.
Well I've just taken the plunge and bought a billet alluminum Woodcraft cover:
I could have probably got away with using a new o-ring and a bit of universal blue but I thought what the hell I'll treat myself. Many will probably think it's a waste of money but from what I've read most of the plastic covers warp over time anyway.
When the aluminium cover arrives should I torque the bolts up to the same 10nm as the plastic one?
Clutch cover oil leak. olisak SV Talk, Tuning & Tweaking 18 18-03-10 04:21 PM
Clutch cover oil leak. dmandub SV Talk, Tuning & Tweaking 12 19-02-10 01:37 AM
clutch cover seal (oil leak) sv-smc SV Talk, Tuning & Tweaking 9 31-01-10 06:47 PM
The never ending clutch cover oil leak badger-666 SV Talk, Tuning & Tweaking 3 20-02-08 07:25 PM
Curvy SV650 clutch cover oil leak bugsy46 Bikes - Talk & Issues 1 06-04-07 11:28 PM
